Boot command petalinux
petalinux-package --boot --fsbl ./images/linux/zynqmp_fsbl.elf --fpga ../../zcu102_hpc0_axieth/zcu102_hpc0_axieth.runs/impl_1/zcu102_hpc0_axieth_wrapper.bit --pmufw ./images/linux/pmufw.elf  --uboot --force
INFO: File in BOOT BIN: "projects/peta2017.1-zcu102/zcu102/petlnx_zcu102/images/linux/zynqmp_fsbl.elf"
INFO: File in BOOT BIN: "projects/peta2017.1-zcu102/zcu102/petlnx_zcu102/images/linux/pmufw.elf"
INFO: File in BOOT BIN: "projects/peta2017.1-zcu102/zcu102_hpc0_axieth/zcu102_hpc0_axieth.runs/impl_1/zcu102_hpc0_axieth_wrapper.bit"
INFO: File in BOOT BIN: "projects/peta2017.1-zcu102/zcu102/petlnx_zcu102/images/linux/bl31.elf"
INFO: File in BOOT BIN: "projects/peta2017.1-zcu102/zcu102/petlnx_zcu102/images/linux/u-boot.elf"
INFO: Generating zynq binary package BOOT.BIN...
[WARNING]: [fsbl_config] a53_x64 | a53_x32 | r5_single | r5_dual will be deprecated, please use 'destination_cpu' attribute of bootloader partition
INFO: Binary is ready.
How should one use destination cpu attribute of bootloader partition in the boot command for petalinux?
That warning bothers me, too, but it doesn't cause any problems.
What it means is that your build/bootgen.bif file contains a line that is currently just fine, but in a future version of bootgen, it will need to be changed.
bootgen is part of Vivado, And Petalinux is also made by Xilinx. Both are version-matched to eachother, so I suspect that if and when that configuration option is deprecated, Petalinux will be updated so that it generates the correct BIF file.
If you're curious:
$ bootgen -bif_help destination_cpu
 ATTRIBUTE   | destination_cpu                                                |
 DESCRIPTION | *** Only for ZynqMP Architecture ***                           |
             | Specifies which core will execute the partition                |
 USAGE       | [destination_cpu=<options>] <partition>                        |
 OPTIONS     | * a53-0                                                        |
             |   a53-1                                                        |
             |   a53-2                                                        |
             |   a53-3                                                        |
             |   r5-0                                                         |
             |   r5-1                                                         |
             |   r5-lockstep                                                  |
             |   pmu                                                          |
 EXPLANATION | Sample BIF - test.bif                                          |
             | all:                                                           |
             |     [bootloader, destination_cpu=a53-0] fsbl.elf               |
             |     [destination_cpu=r5-1] app.elf                             |
             | This specifies that FSBL will be excuted on A53-0 core and     |
             | application on R5-0 core.                                      |
             | Note: FSBL can run either on A53-0 or R5-0 only.               |
             | Note:                                                          |
             | * PMU loaded by FSBL: [destination_cpu=pmu] pmu.elf            |
             | In this flow, BootROM loads FSBL first, and then FSBL loads the|
             | PMU fw.                                                        |
             | * PMU loaded by BootROM: [pmufw_image] pmu.elf                 |
             | In this flow, BootROM loads PMU first and then the FSBL        |
             | So PMU does the power management tasks, before the FSBL comes  |
             | up.                                                            |
