Boot from QSPI is slow
I am using ZC702 evaluation kit. The version of Vivado is 2017.2. The version of petalinux is 2017.2.
When using pre-built image file for QSPI provided in UG1165, the boot time is about 10s which is fast. When build my own linux with the instruction of UG1144 and load the BOOT.bin into QSPI, the boot time is about 70s which is super slow.
I tried to modify the prescale of qspi clock in FSBL in SDK but it does not work. Did anyone encounter similar issue and any solution to it?
Hi @yywilson
Glad to hear that you found the root cause of the delay :)
There are different ways to modify your enviromental variables in U-Boot, one is on runtime and the other one in the build process. For the runtime use case just modify your variables using setenv command and then save it in the QSPI flash device using saveenv command.
For the petalinux use case that would modify your U-Boot compilation in order to set the default enviromental variables as desired. If not wrong you need to create a custom recipe for yocto to modify it. I would suggest you to open a new post as that way we can track better the issue and might me more useful for other users :)
Ibai
Hi @yywilson
I'm not sure if the ZC702 pre-build image loads the bitstream or not but that might be one of the possible root causes. Nevertheless the first thing that you have to do is to identify which step is taking more time than expected in the boot process. BootROM? FSBL? U-Boot? Kernel?
Ibai
Ibai
Hi Ibai,
Thank you for quick response.
The following is part of the output from console port.
SF: Detected n25q128a with page size 256 Bytes, erase size 64 KiB, total 32 MiB
device 0 offset 0x520000, size 0xa80000
Wait for ~70s.
SF: 11010048 bytes @ 0x520000 Read: OK
Using 'conf@1' configuration
Verifying Hash Integrity ... OK
Trying 'kernel@0' kernel subimage
From the information I think reading kernel from address starts from 0x520000 cost a lot of time. And the speed of QSPI is just around 153KB/s.
I also tried that not include bitstream in both petalinux and fsbl.elf. It helps that the time of reading kernel reduced to ~35s but still much slower than pre-built image.
I used pre-built bsp file for ZC702 when building petalinux. Does it define a lower read speed of QSPI?
I'm going to guess that u-boot is reprogramming the the SPI clock when it copies the data from flash to RAM.  I think the command you are looking for is 'sf probe
jeff
Hi @yywilson
So your log clearly points that the issue is loading the image.ub (FIT image containing the kernel, rootfs and ramdisk) so there are just two possible reason for that:
1. The image.ub is bigger:
In this case you have to either reduce your kernel size disabling non used drivers (no big changes) or take a look to your rootfs and disable non used utilities/libraries/applications. You could also change your rootfs type to use ext4 partitions or network based.
2. The interface is running much slower:
Zynq> sf probe -help
sf - SPI flash sub-system
Usage:
sf probe [[bus:]cs] [hz] [mode] - init flash device on given SPI bus and chip select
Take a look to you enviromental variables (printenv command) and modify the sf probe funciton in your FIT image load process and ensure that the [hz] parameter is defined to the highest frequency. (Most of the times the 0 value is used which does not guaranty to use the highest freq).
Ibai
Ibai
Thank you for the response from Ibai and Jeff.
The root cause is that uboot did not set high speed for QSPI. From command "printenv" I can see something like "sf probe 0" which means it did not define the speed of QSPI. Then modify it to "sf probe 0 200000000 0" will solve this issue.
One more question is that where can I fine the configuration file of uboot in Petalinux 2017.2? And although "petalinux-config -c u-boot" is not introduced in any UG, it does show the menuconfig for uboot. Is it safe to modify the configuration?
Hi @yywilson
Ibai
hi, Is your problem solved? I have encountered the same problem as yours :). I'm looking forward to your reply.....................
