Anonymous
Not applicable
Boot from QSPI occurs “SF: Unsupported flash IDs: manuf 00” when startup with XMD tools.
Hi:
    I am trying to boot ZYNQ from QSPI with a demo.
    I do not want to erase the flash in case it can not bootup after reset.
   So I try to  boot ZYNQ in the JTAG mode like following:
XMD%connect arm hw
JTAG chain configuration
Device   ID Code        IR Length    Part Name
 1       4ba00477           4        arm_dap
 2       13722093           6        xc7z010
Enabling extended memory access checks for Zynq.
Writes to reserved memory are not permitted and reads return 0.
To disable this feature, run "debugconfig -memory_access_check disable".
CortexA9 Processor Configuration
Version.............................0x00000003
User ID.............................0x00000000
No of PC Breakpoints................6
No of Addr/Data Watchpoints.........4
Connected to "arm" target. id = 64
Starting GDB server for "arm" target (id = 64) at TCP port no 1235
XMD% source ps7_init.tcl
XMD% ps7_init
PCW Silicon Version : 3.0
XMD% dow u-boot.elf
Processor started. Type "stop" to stop processor
Processor Stop Condition Unknown
Processor Reset .... DONE
Downloading Program -- u-boot.elf
	section, .text: 0x04000000-0x040407a7
	section, .rodata: 0x040407a8-0x0404fcf2
	section, .hash: 0x0404fcf4-0x0404fd1f
	section, .data: 0x0404fd20-0x0405224b
	section, .got.plt: 0x0405224c-0x04052257
	section, .u_boot_list: 0x04052258-0x04052aeb
	section, .rel.dyn: 0x04052aec-0x0405bc63
	section, .bss: 0x04052aec-0x046a6143
Download Progress.10.20.30.40.50.60.70.80.90.Done
Setting PC with Program Start Address 0x04000000
XMD% con
  I can see the  U-BOOT info in the console while the "con" command line typing:
U-Boot 2015.04 (Sep 05 2015 - 23:32:58)
Board:	Xilinx Zynq
I2C:   ready
DRAM:  ECC disabled 512 MiB
MMC:   zynq_sdhci: 0
SF: Unsupported flash IDs: manuf 00, jedec 0000, ext_jedec 00ef
*** Warning - spi_flash_probe() failed, using default environment
In:    serial
Out:   serial
Err:   serial
Board:	Xilinx Zynq
Net:   Gem.e000b000
Hit any key to stop autoboot:  3  2  1  0
Copying Linux from QSPI flash to RAM...
Failed to initialize SPI flash at 0:0
zynq-uboot>
   The CPU appears hang off  for I have no reponse when I type the ENTER button
   I also see a post which has a same phenomenon ( https://forums.xilinx.com/t5/Embedded-Linux/SF-Unsupported-manufacturer-00-unable-to-boot-linux-with-ADI/m-p/346705#M6686), but it seems that we have a different problem.
when I define the macro DEBUG in the u-boot , I can see the detail error info like this:
SF: Got idcodes
00000000: 00 00 00 00 ef 40
  I have a  W25Q128BV QSPI on the board  which has a jedec id of  0xef4018.I dont know why.
  I have serveral question :
  1: Why the QSPI can not be probed successfully?
  2: Why the CPU seems hanged off  in the command line   zynq-uboot> ? Is the error caused by the failed QSPI probe?
  3: Without the method of  XMD startup and flash programme, how can I debug the FSBL with the file fsbl.elf?
  Can anyone help me ? Thanks very much!
Anonymous
Not applicable
I have solve my problems.
All the errors are caused by the hardware configs. like voltage , clock etc.
Till now I think the only way to debug FSBL  is to programme the QSPI flash(the QSPI startup method).
thanks all !
Community Manager
Community Manager
Were you able to program the flash through SDK or Vivado device programmer?
This will give us a clue whether the issue lies in hardware or U-boot.
Anonymous
Not applicable
thanks all !
