Boot hangs after "Freeing unused kernel memory"
Hello I try to boot Linux on ml507 board, but it hangs after:
zImage starting: loaded at 0x00400000 (sp: 0x00895eb0)
Allocating 0x368b38 bytes for kernel ...
gunzipping (0x00000000 <- 0x0040d000:0x005a26a1)...done 0x34c61c bytes
Attached initrd image at 0x005a3000-0x00894187
initrd head: 0x1f8b0808
Linux/PowerPC load: console=ttyUL0 ip=on  root=/dev/ram rw
Finalizing device tree... flat tree at 0x8a2300
Using Xilinx Virtex440 machine description
Linux version 2.6.34 (misha@blub) (gcc version 4.2.2) #0 Tue Jul 6 11:10:02 CEST 2010
Found initrd at 0xc05a3000:0xc0894187
Zone PFN ranges:
  DMA      0x00000000 -> 0x00010000
  Normal   empty
Movable zone start PFN for each node
early_node_map[1] active PFN ranges
    0: 0x00000000 -> 0x00010000
MMU: Allocated 1088 bytes of context maps for 255 contexts
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 65024
Kernel command line: console=ttyUL0 ip=on  root=/dev/ram rw
PID hash table entries: 1024 (order: 0, 4096 bytes)
Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
Memory: 253344k/262144k available (3244k kernel code, 8800k reserved, 136k data, 110k bss, 140k init)
Kernel virtual memory layout:
  * 0xfffdf000..0xfffff000  : fixmap
  * 0xfde00000..0xfe000000  : consistent mem
  * 0xfde00000..0xfde00000  : early ioremap
  * 0xd1000000..0xfde00000  : vmalloc & ioremap
SLUB: Genslabs=11, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Hierarchical RCU implementation.
NR_IRQS:512 nr_irqs:512
clocksource: timebase mult[a00000] shift[22] registered
Mount-cache hash table entries: 512
PCI: Probing PCI hardware
bio: create slab <bio-0> at 0
vgaarb: loaded
Switching to clocksource timebase
IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
TCP established hash table entries: 8192 (order: 4, 65536 bytes)
TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
TCP reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
rootfs image is not initramfs (no cpio magic); looks like an initrd
Freeing initrd memory: 3012k freed
JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
msgmni has been set to 500
alg: No test for stdrng (krng)
io scheduler noop registered
Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
84020000.serial: ttyUL0 at MMIO 0x84020003 (irq = 0) is a uartlite
console [ttyUL0] enabled
84000000.serial: ttyUL1 at MMIO 0x84000003 (irq = 0) is a uartlite
brd: module loaded
PPC 4xx OCP EMAC driver, version 3.54
TCP cubic registered
RAMDISK: gzip image found at block 0
VFS: Mounted root (ext2 filesystem) on device 1:0.
Freeing unused kernel memory: 140k init
but why?
ok it works...
I have the same problem as yours. What did you do to fix it?
Thank you.
You should check that you have your interrupt from the UART going to the interrupt controller and the dts file has been updated to reflect it.
