I am trying to create boot image after performing the steps in the following documentation
https://www.xilinx.com/html_docs/xilinx2019_2/vitis_doc/Chunk375818786.html#hog1570652702356
while I build it shows a warning
WARNING: [fsbl_config] a53_x64 | a53_x32 | r5_single | r5_dual is no more supported. Use 'destination_cpu' attribute for bootloader partition
Is this of any concern?
ZCU102 is stuck after FSBL and ATF . The control is not transferred to U-boot
I have attached the bif file below
//arch = zynqmp; split = false; format = BIN
the_ROM_image:
        [bootloader]zynqmp_fsbl.elf
	[pmufw_image]pmufw.elf
	[destination_device = pl]zcu102_min.bit
	[destination_cpu = a53-0, exception_level =el-3, trustzone]bl31.elf
	[destination_cpu = a53-0, exception_level =el-2]u-boot.elf
All files mentioned are in the same directory
Re: Bootgen
Hi gokulakrishnan.ra@htic.iitm.ac.in
Just change the BIF file like this and try generating BOOT.bin
the_ROM_image:
        [bootloader, destination_cpu=a53-0]zynqmp_fsbl.elf
Best Regards
Shabbir
Re: Bootgen
the_ROM_image:
Best Regards
Shabbir
Re: Bootgen
I changed the bif file and also built the petalinux again
that solved the issue
