Booting Linux Image on ZYBO using JTAG XSCT Commands in Vidavo SDK in Windows 10
I have Vivado SDK installed in Windows 10 and Petalinux installed in Ubuntu virtual machine.
I am wondering if it is possible to download the Petalinux boot image on ZYBO from Windows 10 Vivado SDK using XSCT Commands in Vidavo SDK ?
You can use Petalinux to boot over JTAG
petalinux-boot --jtag --kernel
You can use the --tcl to output the respective commands into a TCL file and run this in XSCT directly.
See ug1157 for more info
