Booting Linux from PL DDR on ZCU106
I would like to do some modifications in u-boot and kernel to boot Linux kernel from PL-DDR intead of PS-DDR. Kinldy let me know how can I access the FSBL and Kernel source in Peta-Linuix yocto SDK and rebuild it.
回复: Booting Linux from PL DDR on ZCU106
shivasankerk@micron.com
For FSBL, you can build fsbl.elf in SDK, and then use "petalinux-package" to package fsbl into BOOT.bin. Or you can generate a patch for your modification and apply this patch to FSBL. You can check this link for patching FSBL in Petalinux.
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18842475/PetaLinux+Yocto+Tips
For Kernel, you can download kernel source and build it with Petalinux. Please check page105 of UG1144(v2018.3) for using external Kernel with PetaLinux. Or on the other way, you can also add patches for your modifcations to Kernel.
Thank you for the response.
Somehow I could not able to generate the patches for fsl as I am not able to clone the git repos due to proxy issues here. I would like to generate the BOOT.bin and image.ub required to boot the ZCU106 board.
Can you provide me the full petalinux-package command to generate these images?
I am trying to modify FSBL and u-boot in petalinux build environment..
Scholar watari
Hi shivasankerk@micron.com
After executing the following command, you can use git with proxy.
Would you try it ?
$ git config --global http.proxy <your proxy setting>
$ git config --global https.proxy <your proxy setting>
Best regards,
