harshaponduri
Booting Zedboard
Hi could some one advice me if there is a way to boot the zedboard with a linux destro (Linaro for example) using JTAG. I will have all the files available for booting the linux bit stream, BOOT.bin file and devicetree.dtb except my SD card interface have some problems and I cannot use an SD card for booting.
achutha
@harshaponduri
If you are using Petalinux you can use the below commands
To download a bitstream to target board:
$ petalinux-boot --jtag --fpga --bitstream <BITSTREAM>
 For Zynq only, you will also need to download the FSBL, you can use the following command:
$ petalinux-boot --jtag --image <PATH to>/zynq_fsbl.elf --extra-xmd "init_user"
 To download newly built <plnx-proj-root>/images/linux/u-boot.elf to target board:
$ petalinux-boot --jtag --u-boot
 To download newly built kernel to target board:
$ petalinux-boot --jtag --kernel
For MicroBlaze, this will download <plnx-proj-root>/images/linux/image.elf on target
board.
For Zynq, this will download <plnx-proj-root>/images/linux/system.dtb and <plnxproj-
root>/images/linux/zImage on target board.
Achutha
