Booting fails at BL31 with message failed to get clock
I'm trying to migrate the Zynq UltraScale+ MPSoC Software Acceleration TRD 2016.4 which is designed for the ES1 version of the ZCU102 board to the ES2 version.
So far, I have updated all the IP blocks in the block design, re-generated the bitstream, exported the hardware, re-generated the device-tree source, rebuilt the SDSOC bitstream and library, rebuilt the whole petalinux and software.
Now, the board boots up to the bootloader, then fails:
Xilinx Zynq MP First Stage Boot Loader
Release 2016.3 Jul 19 2017 - 13:05:17
Platform: Silicon (3.0), Cluster ID 0x80000000
Running on A53-0 (64-bit) Processor, Device Name: XCZU9EG
Processor Initialization Done
================= In Stage 2 ============
SD1 with level shifter Boot Mode
SD: rc= 0
File name is BOOT.BIN
Multiboot Reg : 0x0
Image Header Table Offset 0x8C0
*****Image Header Table Details********
Boot Gen Ver: 0x1020000
No of Partitions: 0x5
Partition Header Address: 0x280
Partition Present Device: 0x0
Initialization Success
======= In Stage 3, Partition No:1 =======
UnEncrypted data Length: 0x3978EC
Data word offset: 0x3978EC
Total Data word length: 0x3978EC
Destination Load Address: 0xFFFFFFFF
Execution Address: 0x0
Data word offset: 0xF5B0
Partition Attributes: 0x20
Destination Device is PL, changing LoadAddress
Bitstream download to start now
XPFW: Calling ROM PWRUP Handler..Done
XPFW: Calling ROM Isolation Handler..Done
DMA transfer done
PL Configuration done successfully
XPFW: Calling ROM PWRUP Handler..Parti
ion 1 Load Success
======= In Stage 3, Partition No:2 =======
UnEncrypted data Length: 0x1800
Data word offset: 0x1800
Total Data word length: 0x1800
Destination Load Address: 0xFFFEA000
Execution Address: 0xFFFEA000
Data word offset: 0x3A6EA0
Partition Attributes: 0x107
Partition 2 Load Success
======= In Stage 3, Partition No:3 =======
UnEncrypted data Length: 0x8
Data word offset: 0x8
Total Data word length: 0x8
Destination Load Address: 0xFFFF0000
Data word offset: 0x3A86A0
Partition 3 Load Success
======= In Stage 3, Partition No:4 =======
UnEncrypted data Length: 0x20EF8
Data word offset: 0x20EF8
Total Data word length: 0x20EF8
Destination Load Address: 0x8000000
Execution Address: 0x8000000
Data word offset: 0x3A86B0
Partition Attributes: 0x104
Partition 4 Load Success
All Partitions Loaded
================= In Stage 4 ============
PMUFW: PmInit:
NODE_APLL #3:
acpu #1 { NODE_APU }
gdma #1 { NODE_GDMA }
dp_dma #1 { NODE_DP }
dbg_tstmp #0 { }
NODE_VPLL #1:
dp_audio #1 { NODE_DP }
NODE_DPLL #2:
ddr #1 { NODE_DDR }
pcie #1 { NODE_PCIE }
NODE_RPLL #5:
dp_video #1 { NODE_DP }
dp_stc #1 { NODE_DP }
sdio1 #1 { NODE_SD_1 }
pcap #0 { }
pl1 #1 { NODE_PL }
pl2 #1 { NODE_PL }
timestamp #0 { }
NODE_IOPLL #29:
dbg_trace #0 { }
dbg_fpd #0 { }
gpu #1 { NODE_GPU }
sata #1 { NODE_SATA }
gtg_ref0 #0 { }
usb3_dual #0 { }
gem0 #1 { NODE_ETH_0 }
gem1 #1 { NODE_ETH_1 }
gem2 #1 { NODE_ETH_2 }
gem3 #1 { NODE_ETH_3 }
usb0_bus #1 { NODE_USB_0 }
usb1_bus #1 { NODE_USB_1 }
qspi #1 { NODE_QSPI }
sdio0 #1 { NODE_SD_0 }
uart0 #1 { NODE_UART_0 }
uart1 #1 { NODE_UART_1 }
spi0 #1 { NODE_SPI_0 }
spi1 #1 { NODE_SPI_1 }
can0 #1 { NODE_CAN_0 }
can1 #1 { NODE_CAN_1 }
cpur5 #1 { NODE_RPU }
iou_switch #0 { }
csu_pll #0 { }
lpd_switch #0 { }
lpd_ls_bus #0 { }
dbg_lpd #0 { }
nand #1 { NODE_NAND }
adma #1 { NODE_ADMA }
pl0 #1 { NODE_PL }
pl3 #1 { NODE_PL }
gem_tsu #4 { NODE_ETH_3, NODE_ETH_2, NODE_ETH_1, NODE_ETH_0 }
dll #2 { NODE_SD_1, NODE_SD_0 }
ams #0 { }
i2c0 #1 { NODE_I2C_0 }
i2c1 #1 { NODE_I2C_1 }
Protection configuration applied
 ATF running on XCZU9EG/silicon v3/RTL5.1 at 0xfffea000, with PMU firmware
NOTICE: BL31: Secure code at 0x0
NOTICE: BL31: Non secure code at 0x8000000
NOTICE: BL31: v1.2(release):5d520c7
NOTICE: BL31: Built : 10:49:57, Jul 13 2017
failed to get clock
failed to get clock
failed to get clock
failed to get clock
failed to get clock
No serial driver found
resetting ...
PMUFW: PmProcessRequest: ERROR invalid payload, status #15
PMUFW: PmProcessAckRequest: ERROR PM operation failed - code 15
As far as I can tell, the FSBL is fine, the bitstream is configured, the PMU_FW loads. Only the bootloader seems to have problems.
I'm using Vivado 2016.4 with Petalinux 2016.3 as suggested in the Wiki.
Can anyone give me a hint what is wrong? I suspect the device tree, but I did not get any errors when building the dtb.
Visitor thiruparan
Re: Booting fails at BL31 with message failed to get clock
how did you enable these debug messages
It has been quite a while, but I would say you choose the message level in the config of the bootloader..
For FSBL see pages 72-74 of UG1137 (v8.0) looking at the FSBL_DEBUG* flags. For PMU FW see page 138 of the same document. For ATF see https://www.xilinx.com/support/answers/71156.html.
