Participant nturner
Booting kernel hangs on unsupported board.
I have a third party host board I'm trying to get running with ADI's Linaro distribution. I had to make a new u-Boot file using the Xilinx u-Boot tool. The boot hangs at the "Starting kernel ..." message, but spits out a bunch of stuff I wasn't able to find useful information on prior to that. Most of the solutions I have been able to find for problems like this are about configuring tty correctly, but since I'm using the ADI image and device tree I don't think that would be a problem. Any thoughts on what might cause this would be appreciated.
U-Boot 2019.01-06985-g195c620 (Mar 14 2019 - 18:31:02 -0700) Xilinx Zynq ZC702
CPU:   Zynq 7z020
Silicon: v3.1
Model: Xilinx Zynq ZC702
I2C:   ready
DRAM:  ECC disabled 1 GiB
MMC:   sdhci@e0100000: 0, sdhci@e0101000: 1
Loading Environment from SPI Flash... SF: Detected s25fl256s_64k with page size 256 Bytes, erase size 64 KiB, total 32 MiB
In:    serial@e0000000
Out:   serial@e0000000
Err:   serial@e0000000
Net:   ZYNQ GEM: e000b000, phyaddr 0, interface rgmii-id
Warning: ethernet@e000b000 (eth0) using random MAC address - 26:30:b7:5e:3c:70
eth0: ethernet@e000b000
411 bytes read in 7 ms (56.6 KiB/s)
Importing environment from SD ...
## Error: "bootcmd_mmc" not defined
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
device 0 offset 0xfc0000, size 0x40000
SF: 262144 bytes @ 0xfc0000 Read: OK
## Executing script at 00020000
Wrong image format for "source" command
SCRIPT FAILED: continuing...
starting USB...
USB0:   ULPI request timed out
zynq ULPI viewport init failed
probe failed, error -1
USB error: all controllers failed lowlevel init
USB is stopped. Please issue 'usb start' first.
starting USB...
ethernet@e000b000 Waiting for PHY auto negotiation to complete... done
BOOTP broadcast 1
BOOTP broadcast 2
DHCP client bound to address 192.168.68.85 (257 ms)
*** Warning: no boot file name; using 'C0A84455.img'
Using ethernet@e000b000 device
TFTP from server 192.168.68.11; our IP address is 192.168.68.85
Filename 'C0A84455.img'.
Load address: 0x0
Loading: *
TFTP server died; starting again
missing environment variable: pxefile_addr_r
starting USB...
BOOTP broadcast 1
DHCP client bound to address 192.168.68.85 (5 ms)
Filename 'boot.scr.uimg'.
Load address: 0x20000
Loading: *
BOOTP broadcast 1
Loading: *
!!! Booting cmd is deprecated (will be removed in 2020).
!!! Please move to distro bootcmd.
Device: sdhci@e0100000
Manufacturer ID: 1b
OEM: 534d
Bus Speed: 50000000
Mode : SD High Speed (50MHz)
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 7.5 GiB
Bus Width: 4-bit
Erase Group Size: 512 Bytes
411 bytes read in 4 ms (99.6 KiB/s)
Loaded environment from uEnv.txt
Running uenvcmd ...
Copying Linux from SD to RAM in uEnv...
4109416 bytes read in 239 ms (16.4 MiB/s)
20643 bytes read in 15 ms (1.3 MiB/s)
** Unable to read file uramdisk.image.gz **
## Booting kernel from Legacy Image at 03000000 ...
   Image Name:   Linux-4.9.0-g2398d50
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    4109352 Bytes = 3.9 MiB
   Load Address: 00008000
   Entry Point:  00008000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 02a00000
   Booting using the fdt blob at 0x2a00000
   Loading Kernel Image ... OK
   Loading Device Tree to 1fff7000, end 1ffff0a2 ... OK
Starting kernel ...
