Visitor dooheon0527
Booting linux on ZCU102 stucks on Waiting for root device /dev/mmcblk0p2....
Hi~
Before, I succeeded in booting zcu102 with below setup
Board : MPSOC Ultrascale ZCU102 revision1.1
vivado 17.4's fsbl, pmu v0.3, device tree(dtb), u-boot 2017.01 linux-xlnx 4.9.0
So, I want to upgrade linux version to 4.14.0
And I upgrade other firmware
pmu v1.1, fsbl(create in newer vivado's SDK), dtb(create with newer dts)
But linux stucks in 'Waiting for root device /dev/mmcblk0p2...'
In my opinion, linux can't detect ip of zcu102 board.
Because there are other logs say 'failed for finding device'
I succeeded in the same board with old linux and other software stacks
But failed in newer stacks....
why?
This is my log.
Xilinx Zynq MP First Stage Boot Loader
Release 2018.3 Jun 21 2019 - 13:10:34
NOTICE: ATF running on XCZU9EG/silicon v4/RTL5.1 at 0xfffea000
NOTICE: BL31: Secure code at 0x0
NOTICE: BL31: Non secure code at 0x8000000
NOTICE: BL31: v2.0(release):xilinx-v2019.1
NOTICE: BL31: Built : 11:33:03, Jun 21 2019
PMUFW: v1.1
U-Boot 2017.01-dirty (Jul 02 2019 - 23:41:35 +0900) Xilinx ZynqMP ZCU102 rev1.0
I2C: ready
DRAM: 4 GiB
ERROR: usb dr_mode not found
at drivers/usb/common/common.c:32/usb_get_dr_mode()
EL Level: EL2
Chip ID: xczu9eg
MMC: sdhci@ff170000: 0 (SD)
reading uboot.env
** Unable to read "uboot.env" from mmc0:1 **
Using default environment
In: serial@ff000000
Out: serial@ff000000
Err: serial@ff000000
Bootmode: LVL_SHFT_SD_MODE1
Net: ZYNQ GEM: ff0e0000, phyaddr c, interface rgmii-id
Warning: ethernet@ff0e0000 using MAC address from ROM
eth0: ethernet@ff0e0000
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc0 is current device
Device: sdhci@ff170000
Manufacturer ID: 3
OEM: 5344
Tran Speed: 208000000
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 14.8 GiB
Bus Width: 4-bit
Erase Group Size: 512 Bytes
reading system.dtb
28013 bytes read in 17 ms (1.6 MiB/s)
reading Image
14014976 bytes read in 968 ms (13.8 MiB/s)
## Flattened Device Tree blob at 04000000
Booting using the fdt blob at 0x4000000
Loading Device Tree to 000000000fff6000, end 000000000ffffd6c ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.14.0 (dhchoi@dtl-unity) (gcc version 6.2.1 20161114 (Linaro GCC Snapshot 6.2-2016.11)) #9 SMP Fri Jun 21 13:44:06 KST 2019
[ 0.000000] Boot CPU: AArch64 Processor [410fd034]
[ 0.000000] Machine model: xlnx,zynqmp
[ 0.000000] earlycon: cdns0 at MMIO 0x00000000ff000000 (options '115200n8')
[ 0.000000] bootconsole [cdns0] enabled
[ 0.000000] efi: Getting EFI parameters from FDT:
[ 0.000000] efi: UEFI not found.
[ 0.000000] cma: Reserved 256 MiB at 0x0000000070000000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] percpu: Embedded 21 pages/cpu @ffffffc87ff7c000 s45080 r8192 d32744 u86016
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: enabling workaround for ARM erratum 845719
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1034240
[ 0.000000] Kernel command line: earlycon clk_ignore_unused root=/dev/mmcblk0p2 rw rootwait
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] software IO TLB [mem 0x6bfff000-0x6ffff000] (64MB) mapped at [ffffffc06bfff000-ffffffc06fffefff]
[ 0.000000] Memory: 3786264K/4194304K available (9532K kernel code, 630K rwdata, 2936K rodata, 512K init, 2157K bss, 145896K reserved, 262144K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff80089d0000 ( 9536 KB)
[ 0.000000] .rodata : 0xffffff80089d0000 - 0xffffff8008cc0000 ( 3008 KB)
[ 0.000000] .init : 0xffffff8008cc0000 - 0xffffff8008d40000 ( 512 KB)
[ 0.000000] .data : 0xffffff8008d40000 - 0xffffff8008ddda00 ( 631 KB)
[ 0.000000] .bss : 0xffffff8008ddda00 - 0xffffff8008ff9130 ( 2158 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf1dc00000 ( 476 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc880000000 ( 34816 MB)
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] RCU event tracing is enabled.
[ 0.000000] RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GIC: Adjusting CPU interface base to 0x00000000f902f000
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arch_timer: cp15 timer(s) running at 99.99MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x170f8de2d3, max_idle_ns: 440795206112 ns
[ 0.000003] sched_clock: 56 bits at 99MHz, resolution 10ns, wraps every 4398046511101ns
[ 0.008240] Console: colour dummy device 80x25
[ 0.012500] console [tty0] enabled
[ 0.015877] Calibrating delay loop (skipped), value calculated using timer frequency.. 199.98 BogoMIPS (lpj=399960)
[ 0.026251] pid_max: default: 32768 minimum: 301
[ 0.030935] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.037508] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.045161] ASID allocator initialised with 65536 entries
[ 0.050417] Hierarchical SRCU implementation.
[ 0.054948] EFI services will not be available.
[ 0.059301] zynqmp_plat_init Platform Management API v1.1
[ 0.064653] zynqmp_plat_init Trustzone version v1.0
[ 0.069589] smp: Bringing up secondary CPUs ...
[ 0.074238] Detected VIPT I-cache on CPU1
[ 0.074264] CPU1: Booted secondary processor [410fd034]
[ 0.074532] Detected VIPT I-cache on CPU2
[ 0.074550] CPU2: Booted secondary processor [410fd034]
[ 0.074804] Detected VIPT I-cache on CPU3
[ 0.074821] CPU3: Booted secondary processor [410fd034]
[ 0.074862] smp: Brought up 1 node, 4 CPUs
[ 0.106280] SMP: Total of 4 processors activated.
[ 0.110953] CPU features: detected feature: 32-bit EL0 Support
[ 0.116752] CPU: All CPU(s) started at EL2
[ 0.120824] alternatives: patching kernel code
[ 0.125962] devtmpfs: initialized
[ 0.132114] random: get_random_u32 called from bucket_table_alloc+0xf8/0x280 with crng_init=0
[ 0.140628] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.140764] random: fast init done
[ 0.153541] futex hash table entries: 1024 (order: 5, 131072 bytes)
[ 0.165212] xor: measuring software checksum speed
[ 0.209877] 8regs : 2302.000 MB/sec
[ 0.253910] 8regs_prefetch: 2052.000 MB/sec
[ 0.298282] 32regs : 2830.000 MB/sec
[ 0.338313] 32regs_prefetch: 2379.000 MB/sec
[ 0.342743] xor: using function: 32regs (2830.000 MB/sec)
[ 0.348170] pinctrl core: initialized pinctrl subsystem
[ 0.353784] NET: Registered protocol family 16
[ 0.358818] cpuidle: using governor menu
[ 0.362867] vdso: 2 pages (1 code @ ffffff80089d6000, 1 data @ ffffff8008d44000)
[ 0.370078] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.377267] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.403329] zynqmp_clk_mux_get_parent() getparent failed for clock: lpd_wdt, ret = -22
[ 0.412537] ARM CCI_400_r1 PMU driver probed
[ 0.423065] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.501516] raid6: int64x1 gen() 404 MB/s
[ 0.573560] raid6: int64x1 xor() 436 MB/s
[ 0.645597] raid6: int64x2 gen() 666 MB/s
[ 0.717643] raid6: int64x2 xor() 593 MB/s
[ 0.789657] raid6: int64x4 gen() 979 MB/s
[ 0.861711] raid6: int64x4 xor() 734 MB/s
[ 0.933780] raid6: int64x8 gen() 1141 MB/s
[ 1.005800] raid6: int64x8 xor() 744 MB/s
[ 1.077885] raid6: neonx1 gen() 717 MB/s
[ 1.149919] raid6: neonx1 xor() 832 MB/s
[ 1.221973] raid6: neonx2 gen() 1156 MB/s
[ 1.294008] raid6: neonx2 xor() 1187 MB/s
[ 1.366062] raid6: neonx4 gen() 1498 MB/s
[ 1.438116] raid6: neonx4 xor() 1427 MB/s
[ 1.510152] raid6: neonx8 gen() 1579 MB/s
[ 1.582217] raid6: neonx8 xor() 1497 MB/s
[ 1.586304] raid6: using algorithm neonx8 gen() 1579 MB/s
[ 1.591667] raid6: .... xor() 1497 MB/s, rmw enabled
[ 1.596598] raid6: using neon recovery algorithm
[ 1.601893] SCSI subsystem initialized
[ 1.605621] usbcore: registered new interface driver usbfs
[ 1.610946] usbcore: registered new interface driver hub
[ 1.616220] usbcore: registered new device driver usb
[ 1.621267] media: Linux media interface: v0.10
[ 1.625728] Linux video capture interface: v2.00
[ 1.630324] pps_core: LinuxPPS API ver. 1 registered
[ 1.635229] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 1.644318] PTP clock support registered
[ 1.648214] EDAC MC: Ver: 3.0.0
[ 1.651534] zynqmp-ipi zynqmp_ipi: invalid resource
[ 1.656225] zynqmp-ipi zynqmp_ipi: Unable to map IPI buffer I/O memory
[ 1.662719] zynqmp-ipi: probe of zynqmp_ipi failed with error -22
[ 1.668935] FPGA manager framework
[ 1.672262] fpga-region fpga-full: FPGA Region probed
[ 1.677263] Advanced Linux Sound Architecture Driver Initialized.
[ 1.683461] Bluetooth: Core ver 2.22
[ 1.686866] NET: Registered protocol family 31
[ 1.691266] Bluetooth: HCI device and connection manager initialized
[ 1.697583] Bluetooth: HCI socket layer initialized
[ 1.702426] Bluetooth: L2CAP socket layer initialized
[ 1.707457] Bluetooth: SCO socket layer initialized
[ 1.712792] clocksource: Switched to clocksource arch_sys_counter
[ 1.718767] VFS: Disk quotas dquot_6.6.0
[ 1.722626] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.733255] NET: Registered protocol family 2
[ 1.737720] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 1.744955] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 1.751816] TCP: Hash tables configured (established 32768 bind 32768)
[ 1.758218] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 1.764196] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 1.770672] NET: Registered protocol family 1
[ 1.775039] RPC: Registered named UNIX socket transport module.
[ 1.780773] RPC: Registered udp transport module.
[ 1.785440] RPC: Registered tcp transport module.
[ 1.790110] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.796951] hw perfevents: no interrupt-affinity property for /pmu, guessing.
[ 1.804030] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 1.812220] audit: initializing netlink subsys (disabled)
[ 1.817491] audit: type=2000 audit(1.747:1): state=initialized audit_enabled=0 res=1
[ 1.817782] workingset: timestamp_bits=62 max_order=20 bucket_order=0
[ 1.832133] NFS: Registering the id_resolver key type
[ 1.837014] Key type id_resolver registered
[ 1.841151] Key type id_legacy registered
[ 1.845135] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 1.851804] jffs2: version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
[ 1.882424] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 1.889646] io scheduler noop registered
[ 1.893523] io scheduler deadline registered
[ 1.897773] io scheduler cfq registered (default)
[ 1.902433] io scheduler mq-deadline registered
[ 1.906931] io scheduler kyber registered
[ 1.936631] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.945606] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 1.955607] brd: module loaded
[ 1.961722] loop: module loaded
[ 1.965406] mtdoops: mtd device (mtddev=name/number) must be supplied
[ 1.972707] libphy: Fixed MDIO Bus: probed
[ 1.977557] tun: Universal TUN/TAP device driver, 1.6
[ 1.982584] CAN device driver interface
[ 1.987049] usbcore: registered new interface driver asix
[ 1.992311] usbcore: registered new interface driver ax88179_178a
[ 1.998341] usbcore: registered new interface driver cdc_ether
[ 2.004138] usbcore: registered new interface driver net1080
[ 2.009759] usbcore: registered new interface driver cdc_subset
[ 2.015642] usbcore: registered new interface driver zaurus
[ 2.021188] usbcore: registered new interface driver cdc_ncm
[ 2.027067] xilinx-axipmon ffa00000.perf-monitor: Probed Xilinx APM
[ 2.033353] xilinx-axipmon fd0b0000.perf-monitor: Probed Xilinx APM
[ 2.039577] genirq: Flags mismatch irq 12. 00000004 (axi-pmon) vs. 00000004 (axi-pmon)
[ 2.047391] xilinx-axipmon fd490000.perf-monitor: unable to register to UIO
[ 2.054249] PLL: shutdown
[ 2.056823] zynqmp_pll_disable() clock disable failed for iopll_int, ret = -13
[ 2.064010] xilinx-axipmon: probe of fd490000.perf-monitor failed with error -16
[ 2.071494] genirq: Flags mismatch irq 36. 00000004 (axi-pmon) vs. 00000004 (axi-pmon)
[ 2.079292] xilinx-axipmon ffa10000.perf-monitor: unable to register to UIO
[ 2.086173] PLL: shutdown
[ 2.088754] xilinx-axipmon: probe of ffa10000.perf-monitor failed with error -16
[ 2.096558] usbcore: registered new interface driver uas
[ 2.101711] usbcore: registered new interface driver usb-storage
[ 2.108094] rtc_zynqmp ffa60000.rtc: rtc core: registered ffa60000.rtc as rtc0
[ 2.115170] i2c /dev entries driver
[ 2.118851] IR NEC protocol handler initialized
[ 2.123196] IR RC5(x/sz) protocol handler initialized
[ 2.128212] IR RC6 protocol handler initialized
[ 2.132710] IR JVC protocol handler initialized
[ 2.137208] IR Sony protocol handler initialized
[ 2.141793] IR SANYO protocol handler initialized
[ 2.146464] IR Sharp protocol handler initialized
[ 2.151136] IR MCE Keyboard/mouse protocol handler initialized
[ 2.156932] IR XMP protocol handler initialized
[ 2.162113] usbcore: registered new interface driver uvcvideo
[ 2.167669] USB Video Class driver (1.1.1)
[ 2.172121] cdns-wdt fd4d0000.watchdog: Xilinx Watchdog Timer at ffffff800801d000 with timeout 60s
[ 2.181030] cdns-wdt ff150000.watchdog: Xilinx Watchdog Timer at ffffff8008036000 with timeout 10s
[ 2.189953] Bluetooth: HCI UART driver ver 2.3
[ 2.194213] Bluetooth: HCI UART protocol H4 registered
[ 2.199314] Bluetooth: HCI UART protocol BCSP registered
[ 2.204614] Bluetooth: HCI UART protocol LL registered
[ 2.209695] Bluetooth: HCI UART protocol ATH3K registered
[ 2.215058] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 2.221320] Bluetooth: HCI UART protocol Intel registered
[ 2.226651] Bluetooth: HCI UART protocol QCA registered
[ 2.231867] usbcore: registered new interface driver bcm203x
[ 2.237488] usbcore: registered new interface driver bpa10x
[ 2.243028] usbcore: registered new interface driver bfusb
[ 2.248475] usbcore: registered new interface driver btusb
[ 2.253901] Bluetooth: Generic Bluetooth SDIO driver ver 0.1
[ 2.259565] usbcore: registered new interface driver ath3k
[ 2.265090] EDAC MC: ECC not enabled
[ 2.268651] EDAC DEVICE0: Giving out device to module zynqmp-ocm-edac controller zynqmp_ocm: DEV ff960000.memory-controller (INTERRUPT)
[ 2.281412] sdhci: Secure Digital Host Controller Interface driver
[ 2.287406] sdhci: Copyright(c) Pierre Ossman
[ 2.291730] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.297624] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.303572] usbcore: registered new interface driver usbhid
[ 2.308981] usbhid: USB HID core driver
[ 2.314672] fpga_manager fpga0: Xilinx ZynqMP FPGA Manager registered
[ 2.321561] pktgen: Packet Generator for packet performance testing. Version: 2.75
[ 2.329117] Netfilter messages via NETLINK v0.30.
[ 2.333749] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 2.339038] Initializing XFRM netlink socket
[ 2.343207] NET: Registered protocol family 10
[ 2.347909] Segment Routing with IPv6
[ 2.351428] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 2.356887] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 2.362938] NET: Registered protocol family 17
[ 2.367203] NET: Registered protocol family 15
[ 2.371618] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 2.384496] Ebtables v2.0 registered
[ 2.388113] can: controller area network core (rev 20170425 abi 9)
[ 2.394211] NET: Registered protocol family 29
[ 2.398598] can: raw protocol (rev 20170425)
[ 2.402835] can: broadcast manager protocol (rev 20170425 t)
[ 2.408465] can: netlink gateway (rev 20170425) max_hops=1
[ 2.413958] Bluetooth: RFCOMM TTY layer initialized
[ 2.418756] Bluetooth: RFCOMM socket layer initialized
[ 2.423862] Bluetooth: RFCOMM ver 1.11
[ 2.427583] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 2.432855] Bluetooth: BNEP filters: protocol multicast
[ 2.438046] Bluetooth: BNEP socket layer initialized
[ 2.442975] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 2.448859] Bluetooth: HIDP socket layer initialized
[ 2.453885] 9pnet: Installing 9P2000 support
[ 2.458042] Key type dns_resolver registered
[ 2.462644] registered taskstats version 1
[ 2.466860] Btrfs loaded, crc32c=crc32c-generic
[ 2.475848] xilinx-psgtr fd400000.zynqmp_phy: failed to get sata_rst reset signal
[ 2.483147] xilinx-psgtr fd400000.zynqmp_phy: failed to get resets: -517
[ 2.493060] rtc_zynqmp ffa60000.rtc: setting system clock to 2018-12-12 12:15:59 UTC (1544616959)
[ 2.501834] clk: Not disabling unused clocks
[ 2.506252] ALSA device list:
[ 2.509042] No soundcards found.
[ 2.512565] Waiting for root device /dev/mmcblk0p2...
Help me!
Mentor watari
Mentor
Re: Booting linux on ZCU102 stucks on Waiting for root device /dev/mmcblk0p2....
Hi @dooheon0527
If my understanding is correct, /dev/mmcblk0 is SD card and /dev/mmmcblk0p2 is 2nd partition of SD card.
If you forgot to install SD card, linux kernel outputs same message.
So, would you make sure SD card, first ?
Also, I suggest you to make sure whether file system is suitable or not on 2nd partition of SD card and kernel setting. (it seems little strange to output RAID mesage... )
Mentor watari
Mentor
Hi @dooheon0527
Visitor dooheon0527
Yes I use 1nd partition for booting software(boot.bin, dtb, kernel Image) and 2nd partition for root filesystem.
And I succeeded boot zcu102 on kernel 4.9.0
But, on kernel 4.14.0 with upgraded firmware(uboot, pmu, fsbl, bl31), I can't boot zcu102.
I don't think SDcard is a cause.
By the logs, linux can't read zcu's third parties. Is fdt have vesion?
Mentor watari
Mentor
Hi @dooheon0527
What do you mean ?
I guess you need upgrade rootfs, too.
Also, could you point out it on the log file and share log file of fdt (flatten device tree) on u-boot ?
I can't find the message about zcu's third parties. 3rd partition ???
