Observer pritya
Booting microzed 7010 board with NFS
Hi All,
       I am using petalinux and vivado 2016.04 and microzed 7010 board for my project.
I have followed the steps =>I have set board in QSPI mode by jumpers. I have TFTPed the imaged.ub on board (run netboot)and mounted the roofs from my PC by NFS.
      For this, when NFS is configed in petalinux-config, I had to disable initramfs in kernel config manually.
If I don't disable initramfs in kernel(petalinux-config -c kernel ) but NFS is configured (petalinux-config), rootfs is being mounted from QSPI.
      I am beginer to petalinux sdk and microzed board. What is the reson makes it mount rootfs from QSPI even if I configured nfs but did not disable initramfs in kernel and my bootargs is
"bootargs=console=ttyPS0,115200 earlyprintk root=/dev/nfs nfsroot=172.16.9.187:/tftpboot/nfsroot,tcp,v4 ip=172.16.9.25 rw"
manualy i cross-verified the mounting of rootfs by NFS from PC to board.
"mount -o nolock -t nfs ip_addr:/tftpboot/nfsroot /home/root/"
Booting consoles are attached.
Any help will be appreciated. Thanks in advance.
Pritam
Visitor zaheer.rm
Re: Booting microzed 7010 board with NFS
Please find answer in the following links -:
http://landley.net/writing/rootfs-howto.html
http://landley.net/writing/rootfs-intro.html
Rgds,
