Booting to QEMU, 2016.4
I like to run a quick check on new apps to make sure they are present, they launch, and they display their --help messages.  Now with Petalinux 2016.4 that fails.  I run "petalinux-boot --qemu --kernel" as before, and now I get the message below.  Clearly something has changed.  It launches okay on the target device when I copy the boot.bin and image.ub to an SD card.  I can't find helpful documentaiton on the new version of petalinux-boot.
$ petalinux-boot --qemu --kernel
INFO: The image provided is a zImage
INFO: TCP PORT is free
INFO: Starting arm QEMU
INFO: qemu-system-aarch64 -M arm-generic-fdt-plnx -machine linux=on -serial /dev/null -serial mon:stdio -display none -kernel /home/daryl/Dropbox/zedboard/petalinux/proj_FFT3b/build/qemu_image.elf -gdb tcp::9000 -dtb /home/daryl/Dropbox/zedboard/petalinux/proj_FFT3b/images/linux/system.dtb -net nic,vlan=1 -net user,vlan=1 -net nic -tftp /tftpboot -device loader,addr=0xf8000008,data=0xDF0D,data-len=4 -device loader,addr=0xf8000140,data=0x00500801,data-len=4 -device loader,addr=0xf800012c,data=0x1ed044d,data-len=4 -device loader,addr=0xf8000108,data=0x0001e008,data-len=4
qemu-system-aarch64: -tftp /tftpboot: The -tftp option is deprecated. Please use '-netdev user,tftp=...' instead.
ERROR:/build/ssw/petalinux/jenkins/new_build_yocto_src_2016.4/qemu/qom/object.c:1576:object_get_canonical_path_component: assertion failed: (obj)
petalinux-qemu-boot: line 726: 16907 Aborted (core dumped) $QEMU_DEBUG ${qemu_cmd} ${qemu_mach} ${nic_list} ${qemu_serial} ${qemu_display} ${qemu_img_opt} -gdb tcp::${start_port} ${dtb_option} ${slirp_option} ${extra_args} ${zynq_fsbl_args} ${aarch64_beta2_args}
sh: line 1: 16995 Segmentation fault (core dumped) /home/daryl/Petalinux/tools/webtalk/bin/unwrapped/lnx64.o/xilproxy > /home/daryl/Dropbox/zedboard/petalinux/proj_FFT3b/.Xil/Webtalk-16991-daryl-HP-ENVY-Notebook/webtalk/xilproxy.log 2>&1
Re: Booting to QEMU, 2016.4
Can you try this?
qemu-system-aarch64 -M arm-generic-fdt-plnx -machine linux=on -serial /dev/null -serial mon:stdio -display none -kernel /scratch/Petalinux/xilinx-zc702-2016.4/build/qemu_image.elf -gdb tcp::9000 -dtb /scratch/Petalinux/xilinx-zc702-2016.4/images/linux/system.dtb -net nic,vlan=1 -net user,vlan=1 -net nic -net user -device loader,addr=0xf8000008,data=0xDF0D,data-len=4 -device loader,addr=0xf8000140,data=0x00500801,data-len=4 -device loader,addr=0xf800012c,data=0x1ed044d,data-len=4 -device loader,addr=0xf8000108,data=0x0001e008,data-len=4
I did (copy-paste, for accuracy), and got this:
qemu-system-aarch64: Unable to get size of device tree file '/scratch/Petalinux/xilinx-zc702-2016.4/images/linux/system.dtb'
qemu-system-aarch64: Error: Unable to load Device Tree /scratch/Petalinux/xilinx-zc702-2016.4/images/linux/system.dtb
I'm not too surprised at that because I have no /scratch directory on my system.  I searched my Petalinux installation for xilinx-zc702-2016.4 to no avail.
/scratch/Petalinux is my local path where petalinux project has been created. Request to replace this with accordingly.
Okay.  I found a qemu_image.elf at the top level of the build directory, so I ran this command:
$ qemu-system-aarch64 -M arm-generic-fdt-plnx -machine linux=on -serial /dev/null -serial mon:stdio -display none -kernel ./build/qemu_image.elf -gdb tcp::9000 -dtb ./images/linux/system.dtb -net nic,vlan=1 -net user,vlan=1 -net nic -net user -device loader,addr=0xf8000008,data=0xDF0D,data-len=4 -device loader,addr=0xf8000140,data=0x00500801,data-len=4 -device loader,addr=0xf800012c,data=0x1ed044d,data-len=4 -device loader,addr=0xf8000108,data=0x0001e008,data-len=4
and got this error:
