Bootlogs stuck after in between while linux os porting on custom board
I have my custom board using SoC xc7z045. I want to build linux kernel for this custom board.
I have created block design using Zynq IP and updated values as per my custom board. After that i have generated .hdf and .bit (bitstream) file for the project and build the linux kernel using petalinux tool
I am getting bootlogs on UART but it stuck after line DRAM: ECC disabled 1 GiB
Bootlogs:
U-boot 2018.01 <Jul 12 2019 - 13:27:58 +0000> Xilinx Zynq ZC702
Board: Xilinx Zynq Silicon: v3.1 DRAM: ECC disabled 1GiB
I am not getting any logs after this. I am not sure what is cause of this
Re: Bootlogs stuck after in between while linux os porting on custom board
Hi @krunal704
Are you booting via JTAG or SD card?
If you're using SD card which files did you copy to the FAT32 partition?
Is this the full boot log, if not can you share the rest?
Did you change MACHINE_NAME in petalinux-config -> DTG Settings? What did you type there?
Did you make any changes to system-user.dtsi or kernel bootargs?
Thanks for your reply
I am using SD Card method, and i copied all the contents of ./images/linux/ directory to BOOT (fat32) partition.
I am not getting boot logs after this and I haven't changes MACHINE NAME and not even in system-user.dtsi or kernel boot args
default kernel bootargs is mentioned below:
console=ttyPS0,115200 earlyprintk root=/dev/mmcblk0p2 rw rootwait
Mentor
Mentor
Hi @krunal704
Would you share the following result on linux ?
fdisk -l <your SD card's device name>
ex)
sudo fdisk -l /dev/sdb
@watari
Here is the output of fdisk -l /dev/sdb
Disk /dev/sdb: 7.4 GiB, 7892631552 bytes, 15415296 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0xc43ccbf8
Device     Boot   Start      End  Sectors  Size Id Type
/dev/sdb1          8192  1056767  1048576  512M  b W95 FAT32
/dev/sdb2       1056768 15415295 14358528  6.9G 83 Linux
I have also tried to boot with jtag using petalinux but still does not work
petalinux-boot --jtag --u-boot --fpga
Hi @krunal704
Can you try booting your system from an SD card with a higher capacity (16/32GB)?
@baltintop Thanks for your reply
As you have suggested, I have tried with 16 GB and 32 GB SD card but still no luck
