Observer chenhao_7
Breakpoints not working while debugging petalinux kernel
I am trying to debug the petalinux kernel I compiled following this tutorial. However, the breakpoints are not always working well. I tried these functions using both hardware and regular breakpoint mode:
  • start_kernel: Hit
  • printk: Hit**
  • do_fork: Not working
  • i2c_dev_init: Not working
After a few tries, I found that all the breakpoints became useless after this boot message: (by stepping over from start_kernel)
** The breakpoint I set on printk worked well before this message and after that, it didn't get hit anymore, either.
Can someone tell me how to handle this?
Thanks!
Scholar austin
Re: Breakpoints not working while debugging petalinux kernel
That is pretty ancient now.
Are all your tools fixed at the release of ISE and SDK this was written for?
If not, then I advise you move into the modern age with Vivado for Zynq rather than struggling with what is now, old tools and flows.
Austin Lesea
Principal Engineer
Xilinx San Jose
Observer chenhao_7
Thanks for your reply and sorry for the confusion. All the tools (Vivado, petalinux and XSDK) I am using are 2017.2 version. I found other tutorials for kernel debugging, such as AR# 67767. Actually, they're talking the same procedure and none of them solved my problem.
I'm seeing the same problem with 2018.1. Setting  a breakpoint in start_kernel works fine, but a lot of other functions do not.. For instance anfc_probe. Its listed in the symbol table
ffffff800860e7d0 l F .text 0000000000000a70 anfc_probe
and the address shows up correctly in the debugger when adding the BP.
I'm guessing this has something to do with it being a built-in module.
Visitor dyessgg
I've hit the same thing in 2018.1 and 2018.2 (Petalinux version == SDK Version == Vivado version).  I can set breakpoints at kernel_start and a few others but a kernel module's _probe function doesn't break.
I've modified the module to make sure the function was exported to the kernel.
I've tried making the breakpoint a hardware, instead of software breakpoint.
I've done this with 32-bit targets (Zynq-7000) and 64-bit targets (ZynqSMP) and same results.
The debugging host machine is the same one used to build the Petalinux image.
I booted via JTAG (petalinux-boot --jtag --kernel)
I get an error message when setting the breakpoint indicating the breakpoint was in multiple files.  I verified this is NOT the case at a source code level.
Any ideas?
Can you please try building the kernel by selecting Image packaging configuration to sdcard in petalinux-config?
Best Regards
Shabbir
Visitor dyessgg
No joy packaging for SD card.  I've booted JTAG and from the SD card and nothing.
It worked one time but not again.
Any other ideas?
