jaibalayya@123
Bringup the ZC706 board with Petalinux OS along with AD9371 drivers (ZC706 + AD9371)
Hi Everyone,
I'm working on Ubuntu 2016.4 with Xilinx Vivado & SDK 2018.1, Petalinux 2018.1 and Petalinux BSP 2018.1 all are downloaded form Xilinx website (https://www.xilinx.com/support/download.html)
two things I have tried
Method 1. With downloaded BSP
petalinux-boot --jtag --prebuilt 3
Method 2.
Created a Vivado project exported Hardware to SDK to get .hdf file
petalinux-create --type project --template zynq --name zc_706
petalinux-config --get-hw-description=<path-to-hdf-directory>
petalinux-config
petalinux-config -c kernel  (Drivers support -> Industrial I/O support -> Analog to digital converters inside there are no AD9371 drivers)
petalinux-config -c rootfs
petalinux-build
In both Methods It bringup the board with Petalinux 2018.1 but I couldn't find AD9371 drivers.
Also I download hdl from here https://wiki.analog.com/resources/fpga/docs/build but when I try make it not generating .hdf file giving some error as show in attachment.
I want to know how to Bringup the ZC706 board with Petalinux OS along with AD9371 drivers from Scratch and more over how we can know that the drivers are present in the OS after board bringup happen.
Thanks in Advance.
gudishak
Hi jaibalayya@123,
method 1
You can use below user guide build petalinux.
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_2/ug1144-petalinux-tools-reference-guide.pdf
Please create your driver files as a patch and apply on recipe-kernel in petalinux project.
method-2
check with analog devices whether they have released a Linux tree where their kernel supports Xilinx configuration
Kranthi
Best Regards
Kranthi
pavan_619@
Hi jaibalayya,
I think this is the old post but I am using the same setup but with zcu102 board. The drivers we will get using ADI layers (meta-adi and meta-adi-xilinx). I assume you have already solved the problem by now but If you have already used this setup I have little query.
There are two versions of ad9371 setup : No-OS and petalinux (linux driver) which is useful?
Thank you
Pavan
