Build busybox for Microblaze
I've seen busybox for Microblaze but for some reason, building it myself results in a lot of problems.
To me it looks like the microblaze target is missing from the busybox build chain. This seems to be true for both the vanilla version and the one from the Xilinx repository.
For example I see this error:
In file included from include/libbb.h:13,
                 from include/busybox.h:10,
                 from applets/applets.c:9:
include/platform.h:165:23: error: byteswap.h: No such file or directory
include/platform.h:166:21: error: endian.h: No such file or directory
include/platform.h:179:3: error: #error "Can't determine endianness"
When I add the __MICROBLAZE__ target to platform.h, I get a bit further but only to run into the next error.
So how do people build busybox for Microblaze, is there some guide I can follow somewhere?
Re: Build busybox for Microblaze
To answer my own question: you can't.
Busybox requires GLIBC or uClibc which can not be compiled for Microblaze with MMU support.
There is a GLIBC toolchain at http://xilinx.wikidot.com/mb-gnu-tools - but with whatever patches that was created is unknown (it seems). But with that GCC (microblaze-unknown-linux-gnu) you can build Busybox, without any modifications.
Note: uClibc does support Microblaze but only without an MMU which will build FLAT binaries.
Anonymous
Not applicable
Sure it can be built. Keep trying, it's doable..  I've done it, and The Petalinux tools do it - and at some point Mr. Linn did it to build the default root filesystem that is avaialble on the wiki.
Terry
We only build busybox with our glibc based tool chain.  We don't do any no MMU support Linux for Microblaze.
