mdkrajnak
Building OpenJDK for PetaLinux with aarch64 is not supported error
I'm trying to build OpenJDK 8 following the discussion here:
https://forums.xilinx.com/t5/Embedded-Linux/Is-it-possible-to-run-Java-application-in-petalinux-Xilinx/m-p/821428
I'm using PetaLinux 2018.2 and targeting a Zinq UltraScale+ SOM on an Avnet board.
When I run petalinux-build I get an error saying aarch64 is not supported:
WARNING: /home/developer/dev/avnet-bsp-2018.2/project-spec/meta-java/recipes-core/openjdk/openjre-8_102b14.bb: openjre-8 does not support aarch64 yet-:--:--
Is there an up to date process for building OpenJDK for PetaLinux? Any recommendations of where to start if I need to tailor the current build files?
mdkrajnak
I should probably add that I'm using the latest commit as of today (Mar 2019) for the meta-java layer on the rocko branch, fbe0b0eb.
eliezer
Hey, did you ever find a solution for this? I've been following along the instructions Sandeep posted in this thread but have run into this same issue.
mdkrajnak
No. We've opted to wait for Petalinux 2019.1 and try again later. Although 2019.1 is out, a BSP is not available for our development boards so it will be a few more weeks, possibly not until after the holidays that we'll try again.
As a backup plan we may try create a custom build of the JRE. It's reportedly not too difficult and allows us to tailor the build for our product.
eliezer
I've been trying to build the aarch64 port of OpenJDK, but it's pretty rough. The only documentation I could find on how to do it was in the README of the source code. And the code is full of errors and warnings, so I'm having trouble compiling it. I will probably try to cross-compile it with the ARM foundation model simulator, instead of the buggy small aarch64 simulator that the README recommends.
If that does end up working, I will probably not ever rebuild it, and just add the final product to my Petalinux build within the build scripts fpr Petalinux.
mdkrajnak
If I can't get the Yocto layers to work I plan to:
1. Try compiling my own JRE based on the following articles:
http://august.nagro.us/small-java.html
http://zlika.github.io/presentations/compile-openjdk8/slides_en.html#/_how_to_compile_openjdk_8_for_embedded_devices
2. Or use a prebuilt JDK. I have downloaded and successfully used the Azul Systems aarch64 JRE on an Xilinix Ultrascrale+ development board from Avnet.
I would prefer to use the AdoptOpenJdk build since I can get a much smaller JRE-only version, but have not tried it yet.
All of this is unfortunately been moved to a much lower priority and probably will remain that way for some months.
eliezer
Where did you find the Azul prebuilt for Aarch64? That sounds like it might save me a lot of headache
mdkrajnak
Azul has JDKs for 8, 11, and 13 here:
https://www.azul.com/downloads/zulu-community/?&architecture=x86-64-bit&package=jdk
In addition to the comminity downloads there's a supported version as well, although I don't know any details about what the support includes.
AdoptOpenJDK builds, which provide a smaller JRE only version are here:
https://adoptopenjdk.net/
Amazon now has an Amazon JDK (Corretto) with builds for Java 8 and 11 for aarch64, here's the link to 8:
https://docs.aws.amazon.com/corretto/latest/corretto-8-ug/downloads-list.html
But again, these are full JDK builds, not JREs.
Corretto has been out for a little while now, but only added aarch64 support quite recently.
Good luck!
eliezer
Thank you so much! I'll suffer through using full JDKs for now, hopefully we get better support for Aarch64 someday.
