Building RFDC application from git sources for ZCU111
I have a problem when I try to complete this "demo" : https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/84378586/Building+RFDC+application+from+git+sources+for+ZCU111
In file toolchain.cmake (https://xilinx-wiki.atlassian.net/wiki/download/attachments/84378586/toolchain.cmake?version=1&modificationDate=1551288369585&cacheVersion=1&api=v2), I don't know where to found this folder : "/home/stephenm/cases/rfdc-standalone/workspace1/rfdc_standalone_bsp/psu_cortexa53_0/include"
As result, I can't compile.
Can you help me ?
Thank you very much
Damien
You will need to build your own standalone bsp for A53 and point to that. This can be done in SDK/Vitis
Thank you for your answer !
Do you have more information to build my own standalone bsp for A53 ? It is not the same than regular Xilinx BSP ?
Thank you
The bsp will have to be generated based on your xsa/hdf. Not sure which version of the tools you are on. In case of Vitis, if you import your xsa you will need to create a platform for it and choose a domain - standalone/freertos or linux. When you select the domain and build the platform, a standalone bsp will be built for your platform.
In case of SDK, what you would do  is export your hdf and then create a hardware platform and bsp.
OK, thank you for your help. I'm using Vivado/SDK. I think I need to create BSP file with petalinux, right ?
I still have a problem :
/embeddedsw/ThirdParty/sw_services/libmetal/src/libmetal/build_libm/lib/include/metal/system/generic/./zynqmp_a53/sys.h:16:10: fatal error: xscugic.h: No such file or directory
#include "xscugic.h"
compilation terminated.
lib/CMakeFiles/metal-static.dir/build.make:62: recipe for target 'lib/CMakeFiles/metal-static.dir/dma.c.obj' failed
make[2]: *** [lib/CMakeFiles/metal-static.dir/dma.c.obj] Error 1
CMakeFiles/Makefile2:93: recipe for target 'lib/CMakeFiles/metal-static.dir/all' failed
make[1]: *** [lib/CMakeFiles/metal-static.dir/all] Error 2
Makefile:140: recipe for target 'all' failed
make: *** [all] Error 2
-> xscugic.h is present and located here : embeddedsw/XilinxProcessorIPLib/drivers/scugic/src/xscugic.h
Why it can't be found ?
Thank you very much
The standalone bsp is different from Petalinux bsp. The standalone bsp needs to be created in Vitis or SDK.
Thank you for your answer.
It is possible to be more specific about standalone bsp ? Do you have a link ? A demo ? Something that can help me ?
And please, it is possible de answers to my second question about xscugic.h ?
Maybe you can try the demo ? Or maybe you have another documentation that can be useful ?
A first step would be to modify the source code of rfdc-data-write-example, to cross-compile it and to use it.
Thank you
