Building u-boot outside petalinux
Hi!
I've got a very simple design for Arty (Microblaze + interrupt controller + timer + uartlite) and I got petalinux to build both linux and u-boot for it succesfully.
However, I want to manually build u-boot to learn about the process, yet I'm having trouble finding what it is that petalinux does in order to compile u-boot for the specific board. I've downloaded Xilinx's u-boot repo, version xilinx-v2017.1 and I've copied the DTS file as uboot-xilinx-v2017.1/arch/microblaze/dts/microblaze-generic.dts However, petalinux's u-boot.elf file boots succesfully on the board, but the version I compile isn't showing any serial output. I'm using microblaze-generic target.
I would like to know what is it that petalinux does in order to do so myself and learn more detail about the process. I haven't even been able to find where it is that petalinux compiles u-boot, so I can't even compare petalinux u-boot with mine, or check its .config file or nothing. It seems like it's been purposefully hidden so I can't get a grasp of what's going on!
Best regards!
@a.gamez
I thought you may use this cloned source to find the **_defconfig file from which you can extract the device tree name.
Anyways, I can suggest other workaround based in your method: you can run another loop like
while true; do find -name .config; done
so instead of complete configuration file, you search for .config file in which all executed configuration are copied in.
Once it is found copy it before petalinux deletes it.
there are things you should not do, unless really badly needed.
compiling u-boot standalone is one of such things. Doable but unless you have a real reason to-do it, you should not.
Just to make sure you are aware about this:
http://www.wiki.xilinx.com/U-boot
There are at least the sources you can inspect.
Yes, I know about that, and also about http://www.wiki.xilinx.com/Build%20U-Boot but I haven't been able to build myself a bootable u-boot. Thanks anyhow!
@a.gamez
When starting your project in Petalinux, before building the project. In configuration menuconfig go to "Linux Component Selection"
In u-boot section, you can choose other than petalinux, in My shot here I chose remote u-boot (but there is other option to choose other local u-boot directory).
Then go to the next field to choose where the other u-boot source
In my case I had to define URL of u-boot
Then in the main configuration window again, go to u-boot Configuration. Then choose in the first field configuration "other" then Petalinux, in the following field you have to write down the name of your configuration file.
But my advice, DO NOT use Petalinux for configuring standalone u-boot, If you have an error, you will repeat complete long compilation cycle
Thanks @moibrahim
I think you've misunderstood me. What I want to do is precisely that, NOT using Petalinux to configure and build u-boot. Your guide is useful for building u-boot from a different codebase using a custom config.
However, what I'm in need of, is extracting from petalinux' u-boot the modifications it does (.dts file, .config, etc) in order to build u-boot for my exported hardware (system.hdf), because I can't find what's the right configuration & dts for building it.
@a.gamez
By default, petalinux is using suitable configuration file that resides in:
u-boot-directory/configs/<<baordName>>_defconfig
So I am not sure what is your board name, but in that directory you can find needed configuration.
For example I have the board zcu102, so Petalinux by default is using "xilinx_zynqmp_zcu102_revB_defconfig".
Inside this configuration file, you can find out which device tree is used for the configuration. It is defined in the field "CONFIG_DEFAULT_DEVICE_TREE"
@moibrahim
Yep. That's what I thought. The problem is that u-boot-directory isn't there at all. u-boot source code doesn't appear anywhere, I think petalinux is deleting the directory after it builds u-boot, so I can't look for those files.
I've searched using find for names that I know that exist under u-boot source code (because I've downloaded it) and they simply don't exist.
EDIT: I can confirm this. I go to build/tmp/work/plnx_microblaze-xilinx-linux/u-boot-xlnx and do the following:
while true; do find -name xilinx_zynqmp_zcu102_revB_defconfig; done
Meanwhile, I run petalinux-build -c u-boot, and for a period of time, the loop above finds that file:
./v2017.01-xilinx-v2017.4+gitAUTOINC+5fa7d2ed06-r0/git/configs/xilinx_zynqmp_zcu102_revB_defconfig
Once petalinux-build -c u-boot finishes, find ceases to well, find that file anymore. Directory git has disappeared. So I cannot inspect what has petalinux really built.
@a.gamez
I can suggest the following.
In Petalinux project directory go to build>>downloads>>git2>>github.com.Xilinx.u-boot-xlnx.git
type pwd in a terminal window to get that path
copy it
then go to your preferred directorz
then use:
git clone <<copied/path>>
This will give you copy of the downloaded u-boot version so you can find your configuration file
@moibrahimThat won't be useful, because petalinux modifies u-boot configuration and places the device tree it uses under u-boot sourcecode, and the compiles. Cloning that directory gives me the untouched source code, but that I can already access via Xilinx' github repository. I need that source code after it's being compiled, so all configuration and files changed are there.
@a.gamez
@moibrahimThank you! That was a very good idea. I asked find to -exec cp {} /tmp/.config and I got the file I wanted.
I've still have had to find and copy a few other files, but at least I'm now on track: I've built a u-boot that finally outputs something on console. It still doesn't work fully, but now I'm progressing.
I still don't believe I have to make such a horrible hack just to get a couple of files. This is something that Xilinx should take a look at, it looks like it's made on purpose just to screw around with people.
I did a different hack, I added
#error stop here
at the end of
./project-spec/meta-user/recipes-bsp/u-boot/files/platform-top.h
then used petalinu-build which then stopped telling me of the error and where the file was.
I agree that petalinux is a nightmare to work with beyond building the reference bsp designs.
