igal_kroyter
C++ on Petalinux questions
I'm trying to port c++ application from visual studio to petalinux during which the following questions have raised:
1) Do the following includes supported:
#include <mutex>
#include <thread>
Because I got the following error: "This support is currently experimental, and must be enabled with the -std=c++11 or -std=gnu++11 compiler options?
2) Where do I set the flag -std=c++11? I have tried in the makefile that petalinux tools provide:
CPPFLAGS += -std=c++11  (failure).
greatgehar
2). Open project properties, navigate to the project settings: C/C++ Build > Settings > Miscellaneous. Add to "Other flags" you any flags.
igal_kroyter
greatgehar, thank you for the reply.
I am compiling with the petalinux command-line tools (petalinux-build -c myapp) not with the XSDK.
Are you familiar with the syntax that is to be used with the petalinux provide makefile?
Igal
rgrossman
I have seen the same errors and found that they didn't make a difference. The compiler defaults to c++11.
I have also added this to the Makefile for myapp:
CFLAGS := $(CFLAGS) -std=c++11
