Observer senkoo
CAN Does not work
Im trying to make CAN work. But when i try anything it says:
no such device.
But when i do:
# ifconfig -a
can0 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
NOARP MTU:16 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:10
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
Interrupt:22
can1 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
Interrupt:23
I have a test case where CAN0 send a little bit of data to CAN1 but they don't seem to exist as a device. I don't really know why they dont exist. I tried ip link set can0 up but then its says no such device again.
What should I do?
Greetings,
Senkoo
Observer senkoo
Re: CAN Does not work
Hey @klasha,
thank you for your respone :). Where can I set this?
Observer senkoo
I really can't find anything in any menu or on the internet..
Are you using the ip from busybox? That one has (or had) some problems with CAN. Try using the regular ip program.
Observer senkoo
Hey @klasha,
