01-16-2020 08:15 AM
I can't get the CAN driver to work in a zynMP device the steps I followed are similar to the ones in this topic
But when I boot petalinux I've got:
root@petalinux:/dev# dmesg | grep can [ 4.537448] vcan: Virtual CAN interface driver [ 4.550478] xilinx_can ff060000.can: failed to add to PM domain pd-can0: -13 [ 5.272471] can: controller area network core (rev 20170425 abi 9) [ 5.282944] can: raw protocol (rev 20170425) [ 5.287180] can: broadcast manager protocol (rev 20170425 t) [ 5.292805] can: netlink gateway (rev 20170425) max_hops=1 [ 5.578775] xilinx_can ff060000.can: failed to add to PM domain pd-can0: -13 [ 5.762307] xilinx_can ff060000.can: failed to add to PM domain pd-can0: -13 [ 6.094055] xilinx_can ff060000.can: failed to add to PM domain pd-can0: -13 [ 6.112014] xilinx_can ff060000.can: failed to add to PM domain pd-can0: -13 [ 6.143677] xilinx_can ff060000.can: failed to add to PM domain pd-can0: -13 [ 6.160939] xilinx_can ff060000.can: failed to add to PM domain pd-can0: -13 [ 6.313941] xilinx_can ff060000.can: failed to add to PM domain pd-can0: -13 [ 6.432130] xilinx_can ff060000.can: failed to add to PM domain pd-can0: -13 [ 6.497870] xilinx_can ff060000.can: failed to add to PM domain pd-can0: -13 [ 6.531858] xilinx_can ff060000.can: failed to add to PM domain pd-can0: -13 [ 6.562910] xilinx_can ff060000.can: failed to add to PM domain pd-can0: -13 [ 6.593899] xilinx_can ff060000.can: failed to add to PM domain pd-can0: -13 [ 6.775193] xilinx_can ff060000.can: failed to add to PM domain pd-can0: -13 [ 7.148501] xilinx_can ff060000.can: failed to add to PM domain pd-can0: -13
And oviously I have not can0 device in /dev.
Any ideas what is wrong/missing?
01-17-2020 09:12 AM
I finally worked out how to work with the CAN network from a petalinux application, I've followed the linux CAN documentation and I've got a simple application sending and receiving packages through CAN.
01-16-2020 09:47 AM
Can you post the complete boot log?
01-16-2020 09:53 AM
01-17-2020 04:11 AM - edited 01-17-2020 09:07 AM
I've finally managed to make some progress with next input in the system-user.dtsi:
can0 { compatible = "xlnx,zynq-can-1.0"; status = "okay"; };
I've got the error can0 failed with error -22:
[ 4.538726] vcan: Virtual CAN interface driver [ 4.547560] xilinx_can can0: invalid resource [ 4.551162] xilinx_can: probe of can0 failed with error -22 [ 5.259766] can: controller area network core (rev 20170425 abi 9) [ 5.270251] can: raw protocol (rev 20170425) [ 5.274480] can: broadcast manager protocol (rev 20170425 t) [ 5.280106] can: netlink gateway (rev 20170425) max_hops=1
But I've got it as network device:
root@petalinux:~# ifconfig -a can0 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00 UP RUNNING NOARP MTU:16 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:10 RX bytes:0 (0.0 B) TX bytes:0 (0.0 B) Interrupt:11 (.........)
And after testing it:
root@petalinux:~# ip link set can0 type can bitrate 1000000 [ 862.218326] xilinx_can ff060000.can can0: bitrate error 0.0% root@petalinux:~# ip link set can0 up root@petalinux:~# cansend can0 -i 0x14 0x33 0x88 interface = can0, family = 29, type = 3, proto = 1
I've checked on the other side and It seems to receive the data fine, so it works.
How could I operate (setup, send and receive packages) the CAN bus from C code or linux application?
01-17-2020 09:12 AM
