CDMA high latency & low bandwidth with Petalinux
we achieved DDR to BRAM bandwidth on Standalone about ~2000MB/s (8192Byte/3850ns)
but with Petalinux(2018.1),  it was 410MB/s (8192Byte/20002ns)
 StandalonePetalinux
ZynqMP1200MHz1333MHz
DMA240MHz300MHz
8K Transfer Latency 3,850 ns20,000 ns
8K Transfer BW2030 MB/s410 MB/s
both system using same hardware but only CPU & DMA Frequency was slightly increased
in petalinux, we handle CDMA like below
1. map_single
2. device_prep_dma_memcpy
3. wait_for_completion_interruptible_timeout
4. dma_unmap_single
Is it normal to get ~400MB/s bandwidth with CDMA in Petalinux?
If the way we control CDMA is wrong, how is it appropriate to approach?
Re: CDMA high latency & low bandwidth with Petalinux
Hi @kruucian,
When you measure the time to complete the transfer in Linux, where do you start and where do you stop your timer? It seems like your measurement is including a lot of operating system related overhead, which is going to hurt the bandwidth numbers for the CDMA hardware.
Deanna
Hi, @demarco
I measured the time 3 different point(map src, map dst, device_prep_dma_cpy+unmap both buffer) and accumulated later.
We decided to abandon all the DMA related Linux/Xilinx-linux APIs.
also abandoned DMA IRQ, we're now polling DMA Regs directly.
now 8KB DDR-to-DDR transfer latency decreased to ~4300ns and so on.
as you know DDR-to-BRAM will be better.
