Participant ejubenville
Cadence I2C timeouts on PicoZed, no pin activity
I can't get the hard I2C 0 core to work in a PicoZed. A probe using "i2cdetect -r 0" results in the following timeout error for all I2C addresses:
cdns-i2c e0004000.i2c: timeout waiting on completion
I see no activity on the SDA/SCL pins coming out of the chip, so I think I must have a configuration problem. In Vivado, I’ve mapped I2C0 to MIO pins 50 (SCL) and 51 (SDA), and exported the ps7_init_gpl.* files needed for uboot in my buildroot configuration. Following is the relevant portion of ps7_init_gpl.c to initialize MIO 50 and 51 pin configurations:
// .. TRI_ENABLE = 0
// .. L0_SEL = 0
// .. L1_SEL = 0
// .. L2_SEL = 0
// .. L3_SEL = 2
// .. Speed = 1
// .. IO_Type = 1
// .. PULLUP = 1
// .. DisableRcvr = 0
EMIT_MASKWRITE(0XF80007C8, 0x00003FFFU ,0x00001340U),
// .. L0_SEL = 0
// .. L1_SEL = 0
// .. L2_SEL = 0
// .. L3_SEL = 2
// .. Speed = 1
// .. IO_Type = 1
// .. PULLUP = 1
EMIT_MASKWRITE(0XF80007CC, 0x00003FFFU ,0x00001340U),
My device tree setup for i2c0 is (including an EEPROM device on the bus):
i2c@e0004000 {
  compatible = "cdns,i2c-r1p10";
  clocks = <&clkc 0x26>;
  interrupts = <0 25 4>;
  i2c-clk = <400000>;
  reg = <0xE0004000 0x1000>;
  #address-cells = <0x1>;
  #size-cells = <0x0>;
  eeprom: eeprom@90 {
    compatible = "at,24c08";
    reg = <0x90>;
The versions of the tools involved with the build:
Vivado 2017.4
buildroot-2017.11.2
linux-xilinx-v2017.2 (includes i2c-cadence.c driver)
uboot-xilinx-v2017.2
Am I missing a configuration step somewhere?  Why can't I see any activity on the MIO 50 and 51 pins during i2cdetect?
Re: Cadence I2C timeouts on PicoZed, no pin activity
Where you're monitoring the signals?
ATM I don't have a picoZed board to inspect ... but I'm curious about the state of "S1" switch that I see on the schematic (pg 3, C-4) that's controlling the mux/demux for your SCL. In the docs I have, I can't find any information about "S1" ... so I'm wondering if it's even on the board. Anyway ... might be worth a look.
--Scott
I'm probing MIO 50 and 51 on our custom baseboard at the point connected to the PicoZed JX3 pins 66 and 64 (MIO 50 and 51, respectively).
I can't find the S1 switch you are referring to on the PicoZed schematic.  I'm using the PicoZed 7015/7030 Rev C04.
http://zedboard.org/sites/default/files/documentations/PicoZed_7015_7030_Rev_C.PDF
I also have a MicroZed that I am willing to build a custom project for to verify I can see I2C activity with my kernel configuration, etc.  I have to dig up an example.
Uugghh ... sorry for the distraction ... I was looking at the picoZed SDR schematic, my apologies.
