Voyager
Voyager
Cadence i2c driver ( kernel 4.6 -> 4.9)
Hi all,
After moving from kernel 4.6 to 4.9 (linux-xlnx) I have several problems and i'm stuck with i2c:
[   10.325053] [IOEXP] Loading ioexpo & mux driver...
[   10.335944] pca954x 0-0070: probe
[   10.335976] i2c i2c-0: master_xfer[0] W, addr=0x70, len=1
[   10.341651] pca954x 0-0070: probe failed
[   10.345646] i2c-core: driver [pca954x] registered
[   10.352820] pca953x 0-0020: probe
[   10.352845] 0-0020 supply vcc not found, using dummy regulator
[   10.358618] i2c i2c-0: master_xfer[0] W, addr=0x20, len=1
[   10.358628] i2c i2c-0: master_xfer[1] R, addr=0x20, len=1
[   10.358643] pca953x 0-0020: failed reading register
[   10.363538] pca953x: probe of 0-0020 failed with error -11
[   10.369084] i2c-core: driver [pca953x] registered
Any idea ? For info, same dts node just update zynq-7000.dtsi
[edit -1]:
root@blo148sg~ # ll /sys/bus/platform/drivers/cdns-i2c/
--w-------    1 root     root          4096 Feb 26 12:28 bind
lrwxrwxrwx    1 root     root             0 Feb 26 12:28 e0004000.i2c -> ../../../../devices/soc0/amba/e0004000.i2c
lrwxrwxrwx    1 root     root             0 Feb 26 12:28 e0005000.i2c -> ../../../../devices/soc0/amba/e0005000.i2c
--w-------    1 root     root          4096 Feb 26 12:28 uevent
--w-------    1 root     root          4096 Feb 26 12:28 unbind
root@blo-148sg ~ # lsmod
Module                  Size  Used by
gpio_pca953x           10198  0
i2c_mux_pca954x         5300  0
root@blo-148sg ~ # grep XILINX running.config | grep I2C
CONFIG_I2C_XILINX=y
Thx :)
Trigger
Voyager
Voyager
Re: Cadence i2c driver ( kernel 4.6 -> 4.9)
Up...
@All Xilinx modo, could you please explain how it's possible to get an error during i2c probing and get the driver regitrated ?
Thx! :)
Trigger
