harish-anil
Can I read a image from HDMI In port into PS directly without any PL interferance
I am trying to develop an application with Open CV in it.
I have an HDMI camera, that would provide real-time feed over HDMI i/p port.
I am looking for hints to develop a C code that could read this HDMI port and do some processing and write to HDMI port out.
Any tutorials that could help me do this.
watari
Hi @harish-anil
This answer is "no". You need to implement some modules, at least HDMI Rx module, in PL side.
Also, I suggest you to refer the following URL.
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/126320678/Zynq+UltraScale+MPSoC+Base+TRD+2019.1
Best regards,
watari
Hi @harish-anil
Best regards,
harish-anil
So you mean I implement HDMI Rx module and then write that to memory and that access the image/video or any data for that sake?
harish-anil
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/126320678/Zynq+UltraScale+MPSoC+Base+TRD+2019.1, with reference to this, I have already worked on 2018.3 and prior to these ones. So I know the video frame read by HDMI Rx module  is written into a frame buffer (wr Frame buffer), how do I access that buffer from a user app in PS ?
watari
Hi @harish-anil
Which method do you want to use. baremetal application os running application on OS ?
Best regards,
harish-anil
Running application on the OS.
watari
Hi @harish-anil
OK.
I suggest you to use "mmap" and/or (V)DMA setting for (V)DMA kernel driver.
These ways are useful for you.
Also, so, you need to implement VDMA and some interconnection to access from CPU, too.
Best regards,
harish-anil
Thank you !!
