irand.simon
Can not compile u-boot for zybo
Under Linux mint 17.1 I have install Vivado & SDK for linux 2014.1.
I follow the tutorial from Digilent to configure u-boot for zybo.
I have try with git both repository, only master-next accept "sudo make CROSS_COMPILE=arm-xilinx-linux-gnueabi- zynq_zybo_config"
but on the next step of the tutorial : "sudo make CROSS_COMPILE=arm-xilinx-linux-gnueabi-" I got :
make: arm-xilinx-linux-gnueabi-gcc: Command not found
/bin/sh: arm-xilinx-linux-gnueabi-gcc: command not found
dirname: missing operand
Try 'dirname --help' for more information.
/bin/sh: arm-xilinx-linux-gnueabi-ld: command not found
Generating include/spl-autoconf.mk
/bin/sh: line 2: arm-xilinx-linux-gnueabi-gcc: command not found
Generating include/tpl-autoconf.mk
arm-xilinx-linux-gnueabi-gcc -DDO_DEPS_ONLY \
-g -Os -ffunction-sections -fdata-sections -fno-common -ffixed-r9 -fno-strict-aliasing -mno-unaligned-access -mfpu=neon -D__KERNEL__ -DCONFIG_SYS_TEXT_BASE=0x4000000 -I/home/simon/FPGA/zybo/u-boot-Digilent-Dev/include -I/home/simon/FPGA/zybo/u-boot-Digilent-Dev/arch/arm/include -fno-builtin -ffreestanding -nostdinc -isystem -pipe -DCONFIG_ARM -D__ARM__ -march=armv5 -Wall -Wstrict-prototypes \
-o lib/asm-offsets.s lib/asm-offsets.c -c -S
make: *** [lib/asm-offsets.s] Error 127
arm-xilinx-linux-gnueabi-gcc is on my PATH and I do not know why it is not found.
Thank you for help me.
Simon.
demke234
The problem is most likely that you have done some things as root (through sudo) already in your kernel tree. You need to change back ownership of the files to your normal user account. Something like this in your linux kernel source tree should do it:
sudo chown -R yourusername .
(There is a dot at the end). Now you can run your usual make command without sudo.
norman_wong
Try the command without "sudo". You should not need to be root to compile u-boot. Your path and the path for root as different.
irand.simon
simon@simon-ThinkPad-T60 ~/FPGA/zybo/u-boot-Digilent-Dev $ make CROSS_COMPILE=arm-xilinx-linux-gnueabi-
/bin/sh: include/generated/timestamp_autogenerated.h.tmp: Permission denied
make: *** [include/generated/timestamp_autogenerated.h] Error 1
sorry it is the same
norman_wong
I can't think of anything else obvious. Try the "which" command to double check your path.
which arm-xilinx-linux-gnueabi-gcc
irand.simon
simon@simon-ThinkPad-T60 /opt/Xilinx/SDK/2014.1 $ which arm-xilinx-linux-gnueabi-gcc
/opt/Xilinx/SDK/2014.1/gnu/arm/lin/bin/arm-xilinx-linux-gnueabi-gcc
yes it is cool
Do I need a symbollic link between "/opt/Xilinx/SDK/2014.1/gnu/arm/lin/bin/arm-xilinx-linux-gnueabi-gcc" and "arm-xilinx-linux-gnueabi-gcc" for the folder where u-boot stands?
Thank you very much for helping me guys
irand.simon
Now ;
simon@simon-ThinkPad-T60 ~/FPGA/zybo/u-boot-Digilent-Dev $ make CROSS_COMPILE=arm-xilinx-linux-gnueabi- zynq_zybo_config
Configuring for zynq_zybo board...
Generating include/autoconf.mk
Generating include/autoconf.mk.dep
So it is close to work, I used sudo to avoid this permission denied but I am stuck
demke234
demke234
Sorry, I obviously meant that you should do that in your u-boot source tree.
