bent93
Can only access 1 out of 4 registers from Linux Kernel
I have a linux Kernel running on my Zedboard. I now want to interact with the logic fabric from a kernel module.
I created an IP with 4x32bit registers, but only seem to be able to read/write a single register. If I do:
	wmb();
	iowrite32(0, base_addr);
	wmb();
	iowrite32(1, base_addr+4);
	wmb();
	iowrite32(2, base_addr+8);
	wmb();
	iowrite32(3, base_addr+12);
And a little after:
	wmb();
	value = ioread32(base_addr);
	seq_printf(p, "0x%x\n", value);
	wmb();
	value = ioread32(base_addr+4);
	wmb();
	value = ioread32(base_addr+8);
	wmb();
	value = ioread32(base_addr+12);
All the reads return 3.
The IP core is still the one generated from the tool, so the fabric-side management of the registers should be working fine.
This is my device in the device tree:
mycore {
        compatible = "dglnt,mycore-1.00.a";
        reg = <0x7e410000 0x1000>;
The Addresses match fine (base_addr = 0x7e410000)
What could be wrong?
bent93
I solved this by calling ioremap for each register. So instead of:
base_addr = ioremap_nocache(res->start, remap_size);
I now do:
	reg0 = ioremap_nocache(res->start, 0x4);
	reg1 = ioremap_nocache(res->start+0x4, 0x4);
	reg2 = ioremap_nocache(res->start+0x8, 0x4);
	reg3 = ioremap_nocache(res->start+0xC, 0x4);
Then, instead of adding the offset in the read and writes, I write to the correct register.
bent93
I now do:
