02-04-2019 10:59 PM - edited 02-04-2019 11:00 PM
I have a Zynq-7030 device with a QSPI attached in QSPI single mode (S25FL256) on a custom board. I want to be able to flash the QSPI device from within linux using the 'flashcp' command in the MTD utils package but I'm having issues.
Some information:
- QSPI peripheral is enabled in block design Zynq IP core
- Can successfully program QSPI device from within SDK using qspi_single mode
- Zynq has boot mode pins set to boot from QSPI and does successfully launch u-boot from QSPI
- u-boot sees QSPI device and reports: "SF: Detected s25fl256s_64k with page size 256 Bytes, erase size 64 KiB, total 32 MiB"
- u-boot is able to perform all basic operations on the device read/write/erase
- Running Ubuntu 16.04 LTS (Linux 4.9.0-xilinx)
- Have CONFIG_SPI_ZYNQ_QSPI driver enabled (built-in) in kernel
- The default (untouched by me) zynq-7000.dtsi file included with the kernel contains the following:
qspi: spi@e000d000 { clock-names = "ref_clk", "pclk"; clocks = <&clkc 10>, <&clkc 43>; compatible = "xlnx,zynq-qspi-1.0"; status = "disabled"; interrupt-parent = <&intc>; interrupts = <0 19 4>; reg = <0xe000d000 0x1000>; #address-cells = <1>; #size-cells = <0>; };
- I reviewed the above dtsi information and it all seems to check out and match what I can find on various other websites/tutorials and the Zynq TRM.
- In my DTS (which #include's the above dtsi) I have the following:
&qspi { u-boot,dm-pre-reloc; status = "okay"; is-dual = <0>; num-cs = <1>; flash@0 { compatible = "s25fl256s1"; reg = <0x0>; spi-max-frequency = <50000000>; #address-cells = <1>; #size-cells = <1>; partition@qspi-boot-bin { label = "qspi-boot-bin"; reg = <0x0 0x2000000>; }; }; };
- I have tried all sorts of various combinations of DTS parameters/values/partitions found on various websites but I still can't see the QSPI device from within linux.
- I have kernel debugging and earlyprintk enabled and I see nothing in the kernel boot log related to any qspi/mtd device. According to this () website I should see something similar to (although not exactly, e.g. different partitions) the following in the kernel boot log:
zynq-qspi e000d000.qspi: master is unqueued, this is deprecated m25p80 spi0.0: s25fl256s1 (32768 Kbytes) 4 ofpart partitions found on MTD device spi0.0 Creating 4 MTD partitions on "spi0.0": 0x000000000000-0x000000100000 : "qspi-boot" 0x000000100000-0x000000450000 : "qspi-linux" 0x000000450000-0x000000470000 : "qspi-device-tree" 0x000000470000-0x000000d70000 : "qspi-rootfs" zynq-qspi e000d000.qspi: at 0xE000D000 mapped to 0xE087A000, irq=51
- The kernel boot log reports no errors/warnings of any kind for any peripheral.
- Running 'ls /dev/mtd*' or 'cat /proc/mtd' returns nothing. The Zynq QSPI driver is clearly not loading.
I have never actually had this much trouble trying to get a Zynq peripheral to work. I think I must just be doing something really dumb or missing something very obvious. I've spent several hours trying to debug this already. I could use a fresh pair of eyes. Does anyone have any ideas? It really shouldn't be this hard...it has to be something simple.
02-05-2019 09:45 AM
HA!! I got it working!! Once I started down the path of thinking "maybe there is something wrong with the MTD subsystem" that lead me to a VERY useful forum post that hadn't popped up in my previous searching!
All I had to do was enable CONFIG_MTD_M25P80 in the kernel. And like the author in the post above states I too used the "make xilinx_zynq_defconfig" and it does not enable the CONFIG_MTD_M25P80 option by default. That should really be fixed...
02-04-2019 11:51 PM
Hi @jwdonal,
I would like to see whether you are using JFFS2 filesystem or initramfs from kernel command line.
Could you please share your complete boot log?
02-04-2019 11:53 PM
could you please add compatible name as mentioned below,
compatible = "micron,m25p80";
02-05-2019 12:17 AM
I have attached boot log as requested. I also tried adding the compatible line you suggested and it did not make any difference, still no MTD devices being enumerated.
As far as file structure I have kernel/DTB on small FAT partition on eMMC and then root file system on EXT4 partition on eMMC. I did not specifically enable any JFFS anywhere that I know of. I am also not using initramfs. Here is the output of the mount command:
# mount /dev/mmcblk0p2 on / type ext4 (rw,relatime,data=ordered) devtmpfs on /dev type devtmpfs (rw,relatime,size=490176k,nr_inodes=122544,mode=755) sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime) proc on /proc type proc (rw,nosuid,nodev,noexec,relatime) tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev) devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000) tmpfs on /run type tmpfs (rw,nosuid,nodev,mode=755) tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k) tmpfs on /sys/fs/cgroup type tmpfs (ro,nosuid,nodev,noexec,mode=755) cgroup on /sys/fs/cgroup/systemd type cgroup (rw,nosuid,nodev,noexec,relatime,xattr,release_agent=/lib/systemd/systemd-cgroups-agent,name=systemd) configfs on /sys/kernel/config type configfs (rw,relatime) /dev/mmcblk0p1 on /mnt/mysdcard_fat type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro)
Thank you so much for the quick response. I would appreciate it so much if you could help me get this working. It is really annoying me at this point.
02-05-2019 09:12 AM - edited 02-05-2019 09:13 AM
Here is some more info. I placed debug dev_info() print statements within the 'probe' method of the drivers/spi/spi-zynq-qspi.c source file and it gets all the way through the probe function and returns 0 (success). So the driver is in the kernel, it is probing, and it is returning success.
But the kernel is not reporting any MTD devices at all. I don't understand what's wrong. I also checked and I have the MTD subsystem enabled in the kernel as well.
x Symbol: MTD [=y] x x Type : tristate x x Prompt: Memory Technology Device (MTD) support x x Location: x x (1) -> Device Drivers x x Defined at drivers/mtd/Kconfig:1 x x Depends on: GENERIC_IO [=y]
There are many other MTD options which are enabled as well. Maybe there is a specific MTD kernel config option that needs to be enabled?
Now that I see that the zynq QSPI kernel driver is indeed probing and returning success I am now at a total loss for what else to try.
02-05-2019 09:45 AM
