hbaumann
Can't access QSPI from linux
Hi everyone !
We have a Zynq-7000 on a customboard and have trouble to access the QSPI from linux.
The QSPI we are using is the ISSI IS25LP128F (http://www.issi.com/WW/pdf/25LP-WP128F.pdf).
FSBL and u-boot are launching fine from QSPI. Output from u-boot:
Loading Environment from SPI Flash... SF: Detected is25lp128 with page size 256 Bytes, erase size 64 KiB, total 16 MiB
OK
dmesg shows the following:
root@devicex:/sysroot/home/root# dmesg | grep spi
[    0.142211] of_get_named_gpiod_flags: can't parse 'cs-gpios' property of node '/amba/spi@e0007000[0]'
[    0.142396] cdns-spi e0007000.spi: registered master spi1
[    0.142542] spi spi1.0: setup mode 0, 8 bits/w, 15000000 Hz max --> 0
[    0.142710] cdns-spi e0007000.spi: registered child spi1.0
[    0.143047] zynq-qspi e000d000.spi: couldn't determine configuration info
[    0.143055] zynq-qspi e000d000.spi: about dual memories. defaulting to single memory
[    0.143304] zynq-qspi e000d000.spi: registered master spi0
[    0.143445] spi spi0.0: setup mode 0, 8 bits/w, 50000000 Hz max --> 0
[    0.143608] zynq-qspi e000d000.spi: registered child spi0.0
Which looks not so bad i would say, but under linux we don't see any partitions:
root@devicex:/dev# cat /proc/mtd
dev:    size   erasesize  name
Our DTS-entry looks like this:
qspi: spi@e000d000 {
        clock-names = "ref_clk", "pclk";
        clocks = <&clkc 10>, <&clkc 43>;
        compatible = "xlnx,zynq-qspi-1.0";
        status = "okay";
        interrupt-parent = <&intc>;
        interrupts = <0 19 4>;
        reg = <0xe000d000 0x1000>;
        #address-cells = <1>;
        #size-cells = <0>;
        u-boot,dm-pre-reloc;
        flash@0{
              compatible = "is25lp128";
              reg = <0x0>;
              spi-tx-bus-width = <1>;
              spi-rx-bus-width = <4>;
              spi-max-frequency = <50000000>;
              #size-cells = <1>;
              partition@qspi-raw {
                        label = "qspi-raw";
                        reg = <0x0 0x1000000>;
We have the following configs enabled:
CONFIG_SPI_ZYNQ_QSPI=y
CONFIG_SPI_MEM=y
CONFIG_SPI_DEBUG=y
CONFIG_MTD=y
CONFIG_MTD_M25P80=y
We are running mainline linux 4.14.106 and had to patch the "spi-zynq-qspi"-driver into it because it was missing. We took it from here https://github.com/Xilinx/linux-xlnx/blob/master/drivers/spi/spi-zynq-qspi.c .
Edit: And also we needed to patch the /drivers/mtd/spi-nor.c to update some definitions:
 	/* ISSI */
-	{ "is25cd512", INFO(0x7f9d20, 0, 32 * 1024,   2, SECT_4K) },
-	{ "is25wp032", INFO(0x9d7016, 0, 64 * 1024,  64,
+	{ "is25lp080d", INFO(0x9d6014, 0, 64 * 1024, 32, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | SPI_NOR_HAS_LOCK) },
+	{ "is25wp080d", INFO(0x9d7014, 0, 64 * 1024, 32, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | SPI_NOR_HAS_LOCK) },
+	{ "is25lp016d", INFO(0x9d6015, 0, 64 * 1024, 32, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | SPI_NOR_HAS_LOCK) },
+	{ "is25wp016d", INFO(0x9d7015, 0, 64 * 1024, 32, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | SPI_NOR_HAS_LOCK) },
+	{ "is25lp032d", INFO(0x9d6016, 0, 64 * 1024, 64, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | SPI_NOR_HAS_LOCK) },
+	{ "is25wp032d", INFO(0x9d7016, 0, 64 * 1024, 64, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | SPI_NOR_HAS_LOCK) },
+	{ "is25lp064a", INFO(0x9d6017, 0, 64 * 1024, 128, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | SPI_NOR_HAS_LOCK) },
+	{ "is25wp064a", INFO(0x9d7017, 0, 64 * 1024, 128, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | SPI_NOR_HAS_LOCK) },
+	{ "is25lp128f", INFO(0x9d6018, 0, 64 * 1024, 256, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | SPI_NOR_HAS_LOCK) },
+	{ "is25wp128f", INFO(0x9d7018, 0, 64 * 1024, 256, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | SPI_NOR_HAS_LOCK) },
+	{ "is25lp256d", INFO(0x9d6019, 0, 64 * 1024, 512, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | SPI_NOR_HAS_LOCK) },
+	{ "is25wp256d", INFO(0x9d7019, 0, 64 * 1024, 512,
+			SECT_4K | SPI_NOR_DUAL_READ |
+			SPI_NOR_QUAD_READ | SPI_NOR_HAS_LOCK |
+			SPI_NOR_4B_OPCODES) },
+	{ "is25lp512m", INFO(0x9d601a, 0, 64 * 1024, 1024,
+			SPI_NOR_QUAD_READ | SPI_NOR_HAS_LOCK) },
+	{ "is25wp512m", INFO(0x9d701a, 0, 64 * 1024, 1024,
+	{ "is25cd512",  INFO(0x7f9d20, 0, 32 * 1024,   2, SECT_4K) },
+	{ "is25lq040b", INFO(0x9d4013, 0, 64 * 1024,   8,
 			SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) },
-	{ "is25wp064", INFO(0x9d7017, 0, 64 * 1024, 128,
+	{ "is25lp080d", INFO(0x9d6014, 0, 64 * 1024,  16,
-	{ "is25wp128", INFO(0x9d7018, 0, 64 * 1024, 256,
+	{ "is25lp128",  INFO(0x9d6018, 0, 64 * 1024, 256,
+			SECT_4K | SPI_NOR_DUAL_READ) },
+	{ "is25lp256",  INFO(0x9d6019, 0, 64 * 1024, 512,
+	{ "is25wp032",  INFO(0x9d7016, 0, 64 * 1024,  64,
+			SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) },
+	{ "is25wp064",  INFO(0x9d7017, 0, 64 * 1024, 128,
+	{ "is25wp128",  INFO(0x9d7018, 0, 64 * 1024, 256,
Can someone give us a hint what we are missing, why dont we see any partitions in  "/proc/mtd" ?
If any additional information is needed please let us know.
jadhavs
Hi @hbaumann,
Please try our Wiki page and you will figureout what is the issue with your DT node is. https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18842262/Zynq+QSPI+Driver
hbaumann
Hi @jadhavs !
Thanks for your reply.
I followed the link and took a look on the example of the DT node.
I saw that the following entrys were different/missing:
is-dual = <0>;
num-cs = <1>;
xlnx,fb-clk = <0x1>;
xlnx,qspi-mode = <0x0>;
So I added them to our DT, which now looks like this:
        status = "okay";
        is-dual = <0>;
        num-cs = <1>;
        #size-cells = <0>;
        flash@0{
              reg = <0x0>;
              #size-cells = <1>;
                        label = "qspi-raw";
But sadly nothing changed.
cat /proc/mtd
Can you help me identify the problem of the DT node in more detail, because i dont really see it.
