Can't build latest kernel
I just downloaded the latest source from git linux-xlnx.git into a clean directory. Then I did the usual make ARCH=arm xilinx_zynq_defconfig followed by the make. But rather than building the kernel the configurator starts to run.
david@ubuntu:~/linux-xlnx$ make
scripts/kconfig/conf --silentoldconfig Kconfig
warning: (USB_ZYNQ_DR_OF) selects USB_ULPI which has unmet direct dependencies (USB_SUPPORT && (ARM || ARM64))
* Restart config...
* Linux/x86 3.18.0 Kernel Configuration
64-bit kernel (64BIT) [Y/n/?] (NEW) ^Cmake[2]: *** [silentoldconfig] Interrupt
make[1]: *** [silentoldconfig] Interrupt
Then I cntrl-C to stop it. Seems 3.18 does not work, my earlier version 3.13 still builds so I don't think I am doing anything wrong.
Dave
Re: Can't build latest kernel
It works now, seems the shell has to be bash. Changed to bash and it works. Note that previous version seemed to work with different shell
I don't see that problem. The master branch@c31fb6b07d3a builds just fine for me using the defconfig. Could you provide more details of what you're doing?
