Can't run petalinux-build without a compiler error
I've been trying to follow the TDR 2014.4 PetaLinux rebuild and am hitting  an error with the compiler trying to locate a header file. I suspect it is a environment issue although I've tried all the tips I've scoured off groups on the internet like petalinux-build -x distclean, etc.
Here is the output of petalinux-build -v around the compiler error and I've attached the build.log file for review as well as a copy of my environment variables.
[ALL  ] ln -s "/opt/pkg/rdf0286-zc702-zvik-base-trd-2014-4/software/petalinux/build/linux/kernel/linux-xlnx/usr" "/opt/pkg/rdf0286-zc702-zvik-base-trd-2014-4/software/petalinux/build/linux/kernel/usr"
[INFO ] build linux/kernel
[ALL  ] make ARCH=arm CROSS_COMPILE=arm-xilinx-linux-gnueabi- O=/opt/pkg/rdf0286-zc702-zvik-base-trd-2014-4/software/petalinux/build/linux/kernel/linux-xlnx KCONFIG_CONFIG="/opt/pkg/rdf0286-zc702-zvik-base-trd-2014-4/software/petalinux/build/linux/kernel/linux-xlnx"/.config -j1 -C /opt/pkg/rdf0286-zc702-zvik-base-trd-2014-4/software/petalinux/build/linux/kernel/download/linux-xlnx all
[ALL  ] make[2]: Entering directory `/opt/pkg/rdf0286-zc702-zvik-base-trd-2014-4/software/petalinux/build/linux/kernel/download/linux-xlnx'
[ALL  ] make[1]: Entering directory `/opt/pkg/rdf0286-zc702-zvik-base-trd-2014-4/software/petalinux/build/linux/kernel/linux-xlnx'
[ALL  ]   HOSTCC  scripts/basic/fixdep
[ALL  ] /opt/pkg/rdf0286-zc702-zvik-base-trd-2014-4/software/petalinux/build/linux/kernel/download/linux-xlnx/scripts/basic/fixdep.c:106:23: fatal error: sys/types.h: No such file or directory
[ALL  ]  #include <sys/types.h>
[ALL  ]                        ^
[ALL  ] compilation terminated.
[ERROR] make[5]: *** [scripts/basic/fixdep] Error 1
[ERROR] make[4]: *** [scripts_basic] Error 2
[ERROR] make[3]: *** No rule to make target `include/config/auto.conf', needed by `include/config/kernel.release'.  Stop.
[ERROR] make[2]: *** [sub-make] Error 2
[ALL  ] make[2]: Leaving directory `/opt/pkg/rdf0286-zc702-zvik-base-trd-2014-4/software/petalinux/build/linux/kernel/download/linux-xlnx'
[ERROR] make[1]: *** [/opt/pkg/rdf0286-zc702-zvik-base-trd-2014-4/software/petalinux/build/linux/kernel/linux-xlnx/vmlinux] Error 2
[ALL  ] make[1]: Leaving directory `/opt/pkg/rdf0286-zc702-zvik-base-trd-2014-4/software/petalinux/build/linux/kernel'
[ALL  ] make: *** [sub_build_component_/kernel/linux-kernel/single/remote] Error 2
[ALL  ] make: Leaving directory `/opt/pkg/rdf0286-zc702-zvik-base-trd-2014-4/software/petalinux/build/linux'
Can someone please help me to resolve this issue?
Re: Can't run petalinux-build without a compiler error
My 2014.4 PetaLinux petalinux-build runs succeed with the attached kernel config.  However if I then just make this single line change to the attached config:
CONFIG_CFG80211=y
then the build fails with the message below.  I've burned many hours trying to get around this because as it is I'm unable to ass the kernel features I need. :(
dwright@dwright-Studio-XPS-9100:~/vtdzynq/vtdpetalinux$ petalinux-build
INFO: Checking component...
INFO: Generating make files and build linux
INFO: Generating make files for the subcomponents of linux
INFO: Building linux
[INFO ] pre-build linux/rootfs/fwupgrade
[INFO ] pre-build linux/rootfs/peekpoke
[INFO ] pre-build linux/rootfs/uWeb
[ERROR] make[5]: *** [silentoldconfig] Error 1
[ERROR] make[4]: *** [silentoldconfig] Error 2
[ERROR] make[1]: *** [/home/dwright/vtdzynq/vtdpetalinux/build/linux/kernel/xlnx-3.17/vmlinux] Error 2
ERROR: Failed to build linux
Sorry for being an idiot.  I was attempting to modify the config file for the kernel manually and an inconsistent set of specifications is very easy to generate this way.  This is what the build was complaining about.
Once I did it right and used the magic "petalinux-config -c kernel" then I was presented with the familiar kernel configuration screen I knew from doing a "make menuconfig" when working with non-peta Linux kernel sources.
@danwwright
Thanks for updating the thread with the root cause details.
@gsanson
Do you still see the issue?
Achutha
