Observer pullanlu
Can the xi2cps driver support multiple i2c controller on the ZC702?
The built-in i2c-controller on the EC702 is i2c0 at address 0xE0004000, we added a 2nd i2c-controller of the same kind i2c1 at the address 0xE0005000. Device tree was changed to include the 2nd i2c-controller. However, the Linux instantiated only the 1st i2c-controller.
The i2c blocks of devicetree.dts was modified as below:
        i2c0: i2c@e0004000 {
            compatible = "xlnx,ps7-i2c-1.00.a";
            reg = <0xE0004000 0x1000>;
            interrupts = <57 0>;
            bus-id = <0>;
            input-clk = <111111111>;
            i2c-clk = <100000>;
            #address-cells = <1>;
            #size-cells = <0>;
        i2c1: i2c@e0005000 {
            reg = <0xE0005000 0x1000>;
            interrupts = <80 0>;
            bus-id = <0>;
            i2c-clk = <100000>;
            #size-cells = <0>;
The Linux boot message related to i2c shows nothing about i2c1:
i2c /dev entries driver
xi2cps e0004000.i2c: 100 kHz mmio e0004000 irq 57
xi2cps e0005000.i2c: reg adap failed: -16
xi2cps: probe of e0005000.i2c failed with error -16
si570 1-005d: registered si570 with default frequency 156250000 Hz
si570 1-005d: set initial output frequency 148500000 Hz
i2c i2c-0: Added multiplexed i2c bus 1
i2c i2c-0: Added multiplexed i2c bus 2
at24 3-0054: 1024 byte 24c08 EEPROM, writable, 1 bytes/write
i2c i2c-0: Added multiplexed i2c bus 3
i2c i2c-0: Added multiplexed i2c bus 4
rtc-pcf8563 5-0051: chip found, driver version 0.4.3
rtc-pcf8563 5-0051: low voltage detected, date/time is not reliable.
rtc-pcf8563 5-0051: rtc core: registered rtc-pcf8563 as rtc0
i2c i2c-0: Added multiplexed i2c bus 5
i2c i2c-0: Added multiplexed i2c bus 6
i2c i2c-0: Added multiplexed i2c bus 7
i2c i2c-0: Added multiplexed i2c bus 8
pca954x 0-0074: registered 8 multiplexed busses for I2C switch pca9548
Linux video capture interface: v2.00
gspca: v2.13.0 registered
usbcore: registered new interface driver uvcvideo
USB Video Class driver (v1.1.0)
WDT OF probe
Can the driver xi2cps support multiple i2c controllers?
Scholar norman_wong
Re: Can the xi2cps driver support multiple i2c controller on the ZC702?
I would guess that "bus-id = <0>" should be "bus-id = <1>" for the i2c1 entry.
