Observer vignesh99
Cannot boot Petalinux on xilinx ZCU102
Hi I am trying to run petalinux on xilinx zcu102. I downloaded the image file from:  https://www.xilinx.com/products/design-tools/ai-inference/ai-developer-hub.html#edge
I have extracted the image file and installed it in the memory card with win32diskImager.
It gives me the following error when I try to log in and boot up via putty
U-Boot 2019.01 (Aug 01 2019 - 10:37:25 +0000)
Model: ZynqMP ZCU102 Rev1.0
Board: Xilinx ZynqMP
DRAM: 4 GiB
EL Level: EL2
Chip ID: zu9eg
MMC: mmc@ff170000: 0
Loading Environment from FAT... sdhci_send_command: MMC: 0 busy timeout increasing to: 200 ms.
sdhci_send_command: MMC: 0 busy timeout increasing to: 400 ms.
sdhci_send_command: MMC: 0 busy timeout increasing to: 800 ms.
sdhci_send_command: MMC: 0 busy timeout increasing to: 1600 ms.
sdhci_send_command: MMC: 0 busy timeout increasing to: 3200 ms.
sdhci_send_command: MMC: 0 busy timeout.
sdhci_set_clock: Timeout to wait cmd & data inhibit
In: serial@ff000000
Out: serial@ff000000
Err: serial@ff000000
Bootmode: LVL_SHFT_SD_MODE1
Reset reason: EXTERNAL
Net: ZYNQ GEM: ff0e0000, phyaddr c, interface rgmii-id
Warning: ethernet@ff0e0000 (eth0) using random MAC address - 96:f1:3b:71:cd:2b
eth0: ethernet@ff0e0000
U-BOOT for xilinx-zcu102-2019_1
ethernet@ff0e0000 Waiting for PHY auto negotiation to complete......................................... TIMEOUT !
Why is this happening? I have tried with other new sd card too, but it shows the same error and doesnt boot.
Please Help. Thank you
Re: Cannot boot Petalinux on xilinx ZCU102
Visitor aantonie
Please read article https://forums.xilinx.com/t5/Embedded-Linux/Cannot-boot-Petalinux-on-xilinx-ZCU102/td-p/1054943 with sd card checklist.
There are described typicall problems with sd card.
Very often there is a need to add to system-user.dtsi following lines:
&sdhc1{
no-1-8-v;
no-1-8-v;
