Cannot clone git://git.xilinx.com/microblaze-gnu.git
I am trying to download and install the MicroBlaze GNU compiler so that I can run a MicroBlaze application outside of the Xilinx SDK platform and on the Linux command line.  I tried following directions on this website: http://xilinx.wikidot.com/mb-gnu-tools
When I enter: git clone git://git.xilinx.com/microblaze-gnu.git
I get the following error:  fatal: unable to connect to git.xilinx.com:
                                            git.xilinx.com[0: 149.199.60.62]: errno=Connection timed out
Our IT person says that there is nothing wrong with our server.  I also tried disabling the firewall with the command "ufw disable" and restarting the computer, but still the same error.
Any suggestions?
Scholar watari
Re: Cannot clone git://git.xilinx.com/microblaze-gnu.git
Hi @agailey
I'm not sure. But Xilinx doesn't accept to open "git" port.
So, I suggest to use other protocol (ex. http or https) instead of git protocol.
BTW, if you want to use microblaze-gnu-gcc, I suggest to install petalinux or XSDK...
If you have petalinux installed at your end. Just try to run source settings.sh of petalinux, this will have microblaze and ARM toolchains, as petalinux is shipped with these toolchains.
Best Regards
Shabbir
Scholar watari
Hi @agailey
