Observer sconvertini
Cannot find linux/interrupt.h
Hi to all,
I'm working with Petalinux 2018.3 running on a MicroZed Rev. F.
I edited a PL project in Vivado 2018.3 as in the following image
I connected four interrupt signals to IRQ_F2P input of the zynq.
In order to recognize these signals as global interrupt, I modified the system-user.dtsi in this way
/include/ "system-conf.dtsi"
chosen {
    bootargs = "console=ttyPS0,115200 earlyprintk uio_pdrv_genirq.of_id=generic-uio";
	amba_pl: amba_pl {
		axi_gpio_0: gpio@41200000 {
			compatible = "generic-uio";
		axi_uartlite_0: serial@42c00000 {
		axi_timer_0: timer@42800000 {
		myAXITimer_0: myAXITimer@43c00000 {
Finally I ensured that the UIO driver was enable in the configuration of the kernel.
After building my petalinux and running on the microzed. I can see this:
root@IMU_plnx:~# cat /proc/interrupts
           CPU0       CPU1
 16:          1          0     GIC-0  27 Edge      gt
 17:          0          0     GIC-0  43 Level     ttc_clockevent
 40:          0          0     GIC-0  40 Level     f8007000.devcfg
 47:          0          0     GIC-0  41 Edge      f8005000.watchdog
 48:          0          0     GIC-0  63 Level     gpio
 49:          0          0     GIC-0  62 Level     timer
 50:          0          0     GIC-0  64 Edge      serial
 51:          0          0     GIC-0  61 Level     myAXITimer
IPI1:          0          0  Timer broadcast interrupts
IPI2:        599        826  Rescheduling interrupts
IPI3:          1          2  Function call interrupts
IPI4:          0          0  CPU stop interrupts
IPI5:          0          0  IRQ work interrupts
IPI6:          0          0  completion interrupts
I can see all four itnerrupt.
But if I try to use the sysroot generated by linux into xilinx sdk, I cannot use the linux/interrupt. since the file does not exist.
Is there any configuration or setting in the kernel or somewhere else to be enabled?
Thank you for your support.
Re: Cannot find linux/interrupt.h
UIO framework does not use by default set of Libray headers, peta linux gives support extranlly for the same.
below one gives exact soultion for your query:
https://forums.xilinx.com/t5/Embedded-Linux/petalinux-including-linux-interrupt-h/td-p/841436
Provide kudos if post is helpful
Thanks & Regards
Satish G
G Satish Kumar
I already saw that link.
if linux/interrupt.h is not used by UIO framework, how can I generate linux/interrupt.h in petalinux?
Thank you
