Newbie rogerstokes
Cannot mount Zynq release 14.7 to modify ramdisk
I unpacked Zynq Release 14.7 into a CentOS 6.4 Virtualbox VM as follows:
        bash# tar xvJf 14.7-release.tar.xv
then removed the U-boot header from uramdisk.image.gz using:
        bash# dd if=uramdisk.image.gz bs=64 skip=1 of=ramdisk.image.gz
unzipping the ramdisk and attempting to mount it fails:
        bash# gunzip ramdisk.image.gz
        bash# sudo mount –o loop ramdisk.image.gz /mnt/ramdisk
        mount: you must specify the filesystem type
        bash# sudo mount –o loop –t vfat ramdisk.image.gz /mnt/ramdisk
        mount: wrong fs type, bad option, bad superblock on /dev/loop1,
               missing codepage or helper program, or other error
so to try and determine why I re-added the header using:
        bash# mkimage –A arm –T ramdisk –C gzip –d ramdisk.image.gz uramdisk2.image.gz
then did a file compare:
        bash# xxd uramdisk.image.gz > u1.hex
        bash# xxd uramdisk2.image.gz > u2.hex
        bash# diff u1.hex u2.hex
        lcl
         < 00000000:  2705 1956 803a b958 5268 139e 0045 89c9  ‘..V.:.XRh...E..
        > 00000000:  2705 1956 98c7 1b07 529f e79b 0045 89c9  ‘..V....R....E..
So perhaps dd modified the start of the unwrapped ramdisk, or the ramdisk itself was corrupted in some way prior to packaging release 14.7 at Xilinx, but it does not affect the operation of U-Boot, while mount detects the error.
The above does seem to conform to the U-Boot manual at http://www.denx.de/wiki/DULG/HowToAddFiles so any help or insights as to what the problem is (or a copy of the ramdisk prior to adding the U-Boot header) would be appreciated.
Re: Cannot mount Zynq release 14.7 to modify ramdisk
Since a few releases the ramdisk is no longer an initrd but an initramfs. I.e. you cannot mount the image but you can unpack it with cpio.
cpio -i < ramdisk.image
 Furthermore, you could check with the 'file' tool what filetype you are actually dealing with.
Newbie rogerstokes
Thanks for the reply, especially the hint on "file". I note the wiki page "Build and Modify a Rootfs" refers to Zynq ramdisks as initrd.
Yeah, it's a wiki. At the time that page was written it was up to date, but things change. Edits welcome ;)
 I am also facing the same issue.
WOuld you please provide me the detail steps on how to add files to ramdisk as I am new to this.
Thanks...
