08-16-2010 08:28 PM
I am able to repeatedly program a Spartan-6 FPGA in slave serial mode when I log into a Embedded Linux running on Spartan-6 using Ethernet (using ssh) but when I log in using the serial port I can only program it once. It says the DONE does not go High. I am using the same program in both cases. Could you provide any hints.
08-24-2010 04:16 PM
You probably need to move this to another forum since this is focused on Linux.
