Newbie pkcardionxt
Cannot send Serial Line Break in Linux 3.8.0, TRD 14.5
The Xilinx Zynq (7020) PS serial port line break Linux functions do not initiate a serial line break condition in Linux 3.8.0, TRD 14.5.  Specifically these Linux functions do not initiate a Serial Line Break: tcsendbreak(<fd>, 0), ioctl(<fd>, TIOCSBRK, 0), ioctl(<fd>, TIOCCBRK, 0).  Digging into the Xilinx_uartps.c code it was found that only STARTBRK was set for a line break system call.  However, according to UG585, STOPBRK (STPBRK) must be cleared in order to set STARTBRK.  Through experimentation, it was found that must be performed in one single write transaction.  The following code update solves the issue:
Update: /drivers/tty/serial/xilinx_uartps.c   Line 613:
From:                    xuartps_writel(XUARTPS_CR_STARTBRK | status,
To:                          xuartps_writel(XUARTPS_CR_STARTBRK | (~XUARTPS_CR_STOPBRK & status),
Note Zynq UG585, Register Control_reg0 Details, states STARTBRK can only be set if STOPBRK is not high, however to implement this the bits must be modified simultaneously in one write transaction, which is not clear in the datasheet.
