Visitor martin91
Capabilities on Xilinx Linux?
Are Linux capabilities available on Xilinx Linux? I'm using a Xilinx Linux kernel 3.6.0 on a Zynq 7045.
As far as I know are capabilities a kernel configuration option, usually in the security options and they should be supported since Linux kernel 2.6., but I couldn't find this option.
thank you for you help in advance
Martin
Visitor martin91
Re: Capabilities on Xilinx Linux?
Ok I've solved the problem.
If somebody has the same problem, besides compiling the libraries libcap2 and lattr for my target I had to enable the kernel option for extended attributes for my file system.
Visitor martin91
I've compiled and installed the libraries libcap2 and lattr for my system. Now I have the commands capsh, getcap, getpcaps, setcap, attr, getfattr and setfattr available. When I try to e.g. get the capabilities from a file, I get the message:
zynq> getcap /mnt/file.txt
Failed to get capabilities of file `/mnt/file.txt' (Operation not supported)
I suppose I havn't configured the kernel correctly, but so far I couldn't figure out what options i have to set exactly.
Does anyone know what options I have to take care of?
Thank you
Martin
Visitor martin91
