Moldan
Changing Petalinux elements Boot order to make Eth0 related App work
I am working with Petalinux 2020.2
My objective is to Auto run an app loaded on an SD, which creates a TCP server and keeps listening in a defined IP (lets say 192.168.1.10) at zc702 evaluation kit boot.
In order to do that, i use Petalinux tools to change default IP adress of the board (so that my App and board keep in the same net) in:
petalinux-config
Subsystem AUTO Hardware Settings->Ethernet Settings
I assign 192.168.1.11(IP)/255.255.255.0(netmask).
Then i copy petalinux image(with my App included in it, set to auto run) to my SD card, following:
Application Auto Run at Startup (page 123) of ug1144
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2020_2/ug1144-petalinux-tools-reference-guide.pdf
I configure board to boot from SD, switch it on, and it fails.
This happens because boot order goes this way:
  1. Some petalinux configurations is loaded
  2. My app is loaded
  3. Eth0 link gets up
At that point, i can only configure my app to keep listening at local IP 127.0.0.1 (as it is not related to Eth0, and gets loaded at boot start).
I would like to change that order to 1,3,2.
How could i do this?
In the App file, i specified:
ifconfig 192.168.1.11 netmask 255.255.255.0
before app is launched and something funny happened, TCP server was successfully set in 192.168.1.10, but afterwards i can not connect to it. When i ping server it tells me that 'It is unreachable', but it states there is no packet loss.
Will investigate a bit more.
Moldan
Well, seems that using
ifconfig 192.168.1.10 netmask 255.255.255.0
# Wait till eth0 link is ready
sleep 8
./my_app
In the .sh which runs my app seem to work, and set eth0 interface without boot config need.
Work flow was pretty much this:
Connect my board and Windows pc through ethernet cable.
Set my windows pc ethernet cable direction to 192.168.1.10/ 255.255.255.0
Config eth0 of Petalinux automatically in boot (before running my app, in the same .sh file) with:
sleep 8 -> Wait 8 secs till eth0 link gets ready (no need to wait to boot)
Launch my TCP server in 192.168.1.10:8888 (automatically in Petalinux boot)
As a fun fact, if you use:
command in the .app load stage, it will ignore the IP settings you declared for boot in petalinux-config.
Moldan
sleep 8
./my_app
