iafolla
Changing fstab in petalinux 2018.2
With Petalinux 2017 I was using the solution explained here to change the fstab in petalinux:
https://forums.xilinx.com/t5/Embedded-Linux/SD-Card-Automount-with-fstab-petalinux/td-p/673174
With petalinux 2018.2 I couldn't make it to work. What is your experience with it?
What other solutions can you suggest me to auto-mount the SDcard when petalinux boots?
Thanks!
shabbirk
Hi @iafolla
Please refer this wiki on auto mounting (How to auto mount SD card in yocto recipes)
http://www.wiki.xilinx.com/PetaLinux+Yocto+Tips
Best Regards
Shabbir
shabbirk
Hi @iafolla
Best Regards
Shabbir
