Participant bpb
Checking sstate mirror taking forever
"Checking sstate mirror object availability" takes a very long time during "petalinux-build".  Is there any way to mitigate this?
Re: Checking sstate mirror taking forever
Since sstate mirror check is part of petalinux-build, you can only speed up this process if you increase parallel threads in petalinux-config ---> Yocto settings ---> Select No of threads here as max 8
Also, it depends on host machine on which you are building, if its fast enough, then build will also be fast
Best Regards
Shabbir
Participant bpb
There is decent CPU utilization by default so I would guess parallel build is enabled.  I tried changing this manually, as suggested, and there doesn't seem to be a difference.
I am seeing ~20 minutes to "petalinux-build" right after a previous "petalinux-build".  4 cores @ 4.4GHz (HTT disabled) Ubuntu 16.04 under VMware Workstation.  No change in anything, just a rebuild.  It seems to spend most of the time "Checking sstate mirror".
I've gone through compiling the kernel on this VM before, and a nop rebuild doesn't take much time.  I suspect the slowdown is related to the Yocto/Bitbake tooling?
Visitor phani.kara
I can confirm that I have the same problem as well. Disconnecting network on the VirtualBox VM used to make it proceed further but even this step does not help now. waiting for 1 hour now with no hope in sight. Rebooting host (and VM) has no effect.
Participant bpb
This appears to be fixed in Petalinux 2017.2 - at least for a simple "Create Block Design" -> "Add Zynq" -> "Generate Bitstream" -> "petalinux-create ..." -> "petalinux-build"
The issue exists with petalinux 2017.2. It takes 45 to 55 mints every time. How to reduce the time?
Observer mascot02
me too,  it take  about 1 hour  just to check sstate mirror  object , and the check occurred  two times;
Observer vacajk
I am using the PetaLinux 2017.2 in the virtual machine of CentOS 7.3.
I found a way to reduce the time of "Checking sstate mirror object availability".
Firstly, you should download the sstate-cache from the webset:
https://www.xilinx.com/support/download/index.html/content/xilinx/en/downloadNav/embedded-design-tools.html
And set the local sstate-cache directions for arm and downloads.
Secondly, before you using the "petalinux-build". You should disconnect the ethernet link of the virtual machine.
Then you can speed up the process of the Checking sstate mirror....
Observer mascot02
thanks ,it make useful for me ;
Visitor eatnafou
This is helpful and it does speed things up. It was showing hours during that stage of the build until I disconnected from the network. I really don't want to have to disconnect the network everytime I want to do a build. Is there any other way beside disconnecting the network? There has to be.
Visitor mrzhang_
petalinux-config->
       YOCTO  setting ->
                           Enbale  sstate cache  internet feeds. (Don't  select this option )
Then, I  need not disconnect my internet, it can feed up compile speed.
