Checking sstate mirror taking forever
"Checking sstate mirror object availability" takes a very long time during "petalinux-build".  Is there any way to mitigate this?
Since sstate mirror check is part of petalinux-build, you can only speed up this process if you increase parallel threads in petalinux-config ---> Yocto settings ---> Select No of threads here as max 8
Also, it depends on host machine on which you are building, if its fast enough, then build will also be fast
Best Regards
Shabbir
There is decent CPU utilization by default so I would guess parallel build is enabled.  I tried changing this manually, as suggested, and there doesn't seem to be a difference.
I am seeing ~20 minutes to "petalinux-build" right after a previous "petalinux-build".  4 cores @ 4.4GHz (HTT disabled) Ubuntu 16.04 under VMware Workstation.  No change in anything, just a rebuild.  It seems to spend most of the time "Checking sstate mirror".
I've gone through compiling the kernel on this VM before, and a nop rebuild doesn't take much time.  I suspect the slowdown is related to the Yocto/Bitbake tooling?
I can confirm that I have the same problem as well. Disconnecting network on the VirtualBox VM used to make it proceed further but even this step does not help now. waiting for 1 hour now with no hope in sight. Rebooting host (and VM) has no effect.
This appears to be fixed in Petalinux 2017.2 - at least for a simple "Create Block Design" -> "Add Zynq" -> "Generate Bitstream" -> "petalinux-create ..." -> "petalinux-build"
The issue exists with petalinux 2017.2. It takes 45 to 55 mints every time. How to reduce the time?
me too,  it take  about 1 hour  just to check sstate mirror  object , and the check occurred  two times;
I am using the PetaLinux 2017.2 in the virtual machine of CentOS 7.3.
I found a way to reduce the time of "Checking sstate mirror object availability".
Firstly, you should download the sstate-cache from the webset:
https://www.xilinx.com/support/download/index.html/content/xilinx/en/downloadNav/embedded-design-tools.html
And set the local sstate-cache directions for arm and downloads.
Secondly, before you using the "petalinux-build". You should disconnect the ethernet link of the virtual machine.
Then you can speed up the process of the Checking sstate mirror....
thanks ,it make useful for me ;
This is helpful and it does speed things up. It was showing hours during that stage of the build until I disconnected from the network. I really don't want to have to disconnect the network everytime I want to do a build. Is there any other way beside disconnecting the network? There has to be.
petalinux-config->
       YOCTO  setting ->
                           Enbale  sstate cache  internet feeds. (Don't  select this option )
Then, I  need not disconnect my internet, it can feed up compile speed.
