vcouvert
Chromium - Petalinux 2018.2 - OpenGL - Webgl
Hi all,
Using latest Petalinux version (2018.2) I managed to add Chromium to my generated rootfs for ZU3EG platform.
However, when I launch Chromium, I get an error about GL context:
[2382:2382:0712/175115:ERROR:gl_factory.cc(48)] Requested GL implementation is not available.
[2382:2382:0712/175116:ERROR:gpu_child_thread.cc(348)] Exiting GPU process due to errors during initialization
[2351:2373:0712/175116:ERROR:browser_gpu_channel_host_factory.cc(123)] Failed to launch GPU process.
And when I try to browser a Web page using Webgl components, they are not displayed.
Any idea about how to fix this issue?
watari
konrad.ley@valeo.com
I strongly suggest using PetaLinux 2018.3 to use Mali400 as gpu.
Also I suggest sharing x window’s log file to investigate the route cause.
Best regards,
vcouvert
Thanks for your feedback, i'll try your solution.
Did you managed to make WebGL work ? (http://webglsamples.org/aquarium/aquarium.html for example).
Thanks for your help.
vcouvert
Thanks for your message, i'll migrate to 2018.3 and see if it works better.
Sorry, i was maybe a bit too enthusiatic.
With the petalinux 2017.3 image which shipped with the ultra96 board i start chromium with --use-gl=egl option and your webgl sample looks like petalinux2017.3chromiumwebgl.png.
On petalinux 2018.3 with x11 it doesn't work at all.
On petalinux 2018.3 with wayland and chromium-ozone-wayland it looks like petalinux2018.3chromiumozonewaylandwebgl.png
vcouvert
Thanks for your reply and screenshots.
Would you say that it worked better with 2017.3 shipped image than with your 2018.3 own image?
I never managed to make this demo work on my board, so I will try with a 2018.3 own image (wayland and x11) and see...
Regards.
Sorry, when i run chromium with unchecked "use hardware acceleration when available" i get "It does not appear your computer supports WebGL.
Now i tried chromium from https://github.com/OSSystems/meta-browser on x11. It seems to work without artifacts at 6 fps. Rather slow compared to wayland with 12 fps but on wayland it's showing the artifacts from my previous post.
The steps I took are;
1. Add yocto layer meta-rust and meta-browser according to http://www.zachpfeffer.com/single-post/Add-a-Yocto-Layer-to-a-PetaLinux-Project-and-Build-a-Recipe-in-the-Layer-with-PetaLinux-Tools
2. Add
IMAGE_INSTALL_append = " chromium-x11"
to project-spec/meta-user/conf/petalinuxbsp.conf
3.
petalinux-build
vcouvert
Hi all,
Thanks for your help and tips!
I installed 2018.3 version and, using your information, I managed to get WebGL samples and my board using Wayland/Weston. I just had to wait hours until Chromium get compiled :-)
Since I would like to keep my Xfce (which seems to not support Wayland for the moment), I will try in the next days to compile chromium-x11 (from  https://github.com/OSSystems/meta-browser) and see if it works too.
Thanks again for your help.
Vincent
vcouvert
I also tried the chromium-x11 based solution and it worked too (with a lower FPS)!
Thansk again for your help.
sulcas.mindaugas
I wanted to ask if you used BSP for ultra96 board to build petalinux image with wayland backend? Becouse I tried to build petalinux image with wayland backed using ultra96 BSP and I get error webkitgtk do_compile failed.
yes, i used 2018.3 Bsp for ultra96 board from http://www.zedboard.org/support/design/24166/156.
I followed the instructions given on https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18841928/Xilinx+MALI+driver in the "Wayland/GBM backend:"/"2018.3:" section.
It worked without error. Maybe you didn't unselect some x11 dependent package in rootfs config?
sulcas.mindaugas
Thank you for quick reply, I have unselected 'packagegroup-petalinux-matchbox' and 'packagegroup-petalinux-x11' as instructed https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18841928/Xilinx+MALI+driver but I still get error.
sulcas.mindaugas
So I guess I found my problem. My system runs out of ram. Screenshot_20190718-091735_Gallery.jpg
