Clocks in device tree
I've noticed in the device tree files, each node has a 'clock-names' tag, for example:
spi0: spi@ff040000 {
			clock-names = "ref_clk", "pclk";
And in the clk-ccf file there are some numbers like:
&spi0 {
	clocks = <&zynqmp_clk 58>, <&zynqmp_clk 31>;
But I haven't found neither those clock names or numbers referenced anywhere else, so what's the purpose of this?
Re: Clocks in device tree
Device tree ZynqMP (and Zynq) clock names are connected to Xilinx Linux clocking framework device driver (see Linux kernel sources: drivers/clk/zynqmp/* files).
There is where you will find connections between device tree clock names and clocks in ZynqMP HW.
Linux kernel integrates clocking support (relations, control, ...) via its Common Clk Framework
Some Xilinx ZynqMP clocking info is also here Common Clock Framework for Zynq Ultrascale+ MPSOC
WBR Primoz
Teacher drjohnsmith
Am I guessing this is the pre configured IP blocks of Xilinx,
In which case, Id not worry, it could be anything from important , in which case dont touch, to redundant "old" code, in which case the tools will ignore ,
If its in the IP, either way , not much you can do about it ,
No, that's in almost all the PS peripherals
WBR Primoz
