puv97
Cloud connection
I'd like to do a SVM Machine Learning training in the Cloud (probably Azure) using the ZCU102 development kit with the UltraScale+. I'm not sure if I need an operating system (Ubuntu/Petalinux) to send the information to the cloud, then do the training and return the information to the FPGA, or if it is better to send the information using something included in the Vivado HLS tool.
I'm new using FPGAs in the IoT world. Thanks
robinplc2
Hey @puv97  I dont know if you are aware of the Xilinx collaboration with AWS and AZURE for IOT ML  related works here : https://www.xilinx.com/applications/industrial/analytics-machine-learning.html .
Plus you can find a working solution with AWS Sagemaker and AWS IOT Greengrass here : https://github.com/splineai-cloud/COVID-XS
Hope it helps.
Beste,
