bilginmu16
Cmake on Petalinux
Hello everyone,
I have a zynq cora board. Petalinux is running on it. I want to build my project on petalinux. However  need to cmake.  Cmake should run on petalinux. How can I add cmake to petalinux ? Is there any way to do this ?
shabbirk
Hi @bilginmu16
If you want to add just cmake utility, follow these steps:
Add IMAGE_INSTALL_append = " cmake"  to the file: project-spec/meta-user/recipes-core/images/petalinux-image-full.bbappend
Enable it in roots: petalinux-config -c rootfs ->  user packages -> [*] cmake
Best Regards
Shabbir
shabbirk
Hi @bilginmu16
Best Regards
Shabbir
bilginmu16
Thanks @shabbirk
 Petalinux has petalinux-image.bbappend instead of petalinux-image-full.bbappend.
I apply the same procedure as you said  for petalinux-image.bbappend. There is no problem. I added cmake utility. I want to know that how to use petalinux-image.bbappend and detailed information. Where can I get that informations ?
Thanks a lot again.
shabbirk
Hi @bilginmu16
It is like any other package adding to petalinux. Refer UG1144 (Page 82)
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2019_1/ug1144-petalinux-tools-reference-guide.pdf
Best Regards
Shabbir
bilginmu16
Thanks your reply @shabbirk
I want to know one more thing. I added git to petalinux. But git features are diminished. For example "submodule" command, there is no "submodule" command. Is there any way to add ?
King regards
rockydemag
In Petalinux 2020.2, this will be added to /project-spec/meta-user/conf/user-rootfsconfig as
CONFIG_cmake
