Visitor gurusamy
Compiler and linker errors while building a demo project!
I am using ZU3EG board from Xilinx and a base-board from Trenz. I tried to run FreeRTOS on Cortex-R5 and according to their documents, I have created a new project using Xilinx SDK (version 17.1). Generation of demo sources went fine without any errors but, when I compile the generated sources/project, I get the following errors: (I have also tried with Vivado SDK 16.4 but, I get the same errors)
From pre-processor/compiler:
"Compiling FreeRTOS"
portZynqUltrascale.c:78:20: fatal error: xttcps.h: No such file or directory
compilation terminated.
make[1]: *** [libs] Fehler 1
make: *** [psu_cortexr5_0/libsrc/freertos901_xilinx_v1_0/src/make.libs] Fehler 2
From linker:
make all
'Building target: Test4.elf'
'Invoking: ARM R5 gcc linker'
armr5-none-eabi-gcc -Wl,-T -Wl,../src/lscript.ld -L../../Test4_bsp/psu_cortexr5_0/lib -o "Test4.elf"  ./src/freertos_hello_world.o   -Wl,--start-group,-lxil,-lfreertos,-lgcc,-lc,--end-group
d:/programme/sdk/2017.1/gnu/armr5/nt/gcc-arm-none-eabi/bin/../lib/gcc/arm-none-eabi/5.2.1/../../../../arm-none-eabi/bin/ld.exe: cannot find -lfreertos
collect2.exe: error: ld returned 1 exit status
make: *** [Test4.elf] Fehler 1
(I am sorry if this issue has been already discussed here; if so, please tell me the right direction for me!).
Any idea/help to over-come these errors will be appreciated.
Many thanks!
Observer jesuslazaro
Re: Compiler and linker errors while building a demo project!
xttcps.h is included when selecting any TTC peripheral inside Low Speed -> Processing Unit -> TTC
Jesús
Observer russellsnow
"xttcps.h is included when selecting any TTC peripheral inside Low Speed -> Processing Unit -> TTC"
How do I use this? Is this in Vivado? SDK? Is this what causes the error or what fixes it?
In Vivado you must select the TTC so that in SDK xttcps.h is available.
What if you are not using TTC in your design?
From what I understand, freertos uses it, so you should use it in your design.
